Question about HP Officejet 5510 All-In-One Thermal Printer
Reinstall HP 57 cartridge
Need diagram of correct angle to hold cartridge to slide in.
I,
  • 489 Answers
Download PDF manual for this printer at:
http://h10032.www1.hp.com/ctg/Manual/bpu72474.pdf
Posted on Mar 22, 2009
I am looking for a color access door for a print carriage on an hp psc2210 all in one printer. (C8654A)
  1. If you are putting in a new cartridge, make sure to remove the tape.
  2. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  3. Fit the cartridge into the proper carriage.
    • The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
    • The carriage with the blue latch is for the tri-color cartridge (HP 57).
    Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
  4. Hold the hinged flap of the latch out while lowering the latch.
  5. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
  6. Close the cartridge access door.
  7. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Aug 23, 2011 | HP PSC 2210 All-In-One InkJet Printer
HP officejet 6110 all-in-one. 4 years old - is suddenly giving a problem. The message "Error: Left cartridge incorrect" keeps appearing. The left cartridge is the correct one (HP 57) and is...
i would suggest you to remove the left cartridge once and clean its golden metal contacts with soft cloth and reinstall it again.
this can give some difference
Sep 17, 2008 | Office Equipment & Supplies
How do i change the cartridge
See below: Also is a link the the manual for your unit the maunal has pictures: Page 62 of the manual list the procedure. (page 72 in the adobe file)
Manual
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
Note: It is normal to see ink buildup in the print cartridge slots.
Print-carriage
access door
hp officejet 5500 series
chapter 8
64 maintain your hp officejet
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the pink tape by using the pull
tab.
Caution! Do not touch the copper contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
It must slide in at a slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
Note: You must install both print cartridges in order for your HP Officejet to
work.
reference guide
65
6 Close the print-carriage access door. Within a few minutes, a print
cartridge alignment page prints.
Feb 25, 2011 | HP Officejet 5510 All-In-One Thermal...
Still getting Print Cartridge Error after installing new HP cartr
please check the position of the catridges installed. it should be in a correct position. or you might have replaced the catridges in a wrong slot. if it does not work out then either connect your printer to different computer for printing or uninstall the software from your computer, then again reinstall the software.
Oct 29, 2009 | HP Officejet 5510 All-In-One Thermal...
How do I put new cartridge in
Follow this procedure to install print cartridges in you printer.
touch only the black plastic, gently remove the tape by using the pink pull tab.
Caution! Do not touch the gold-colored contacts or ink nozzles.
4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
It must slide in at a upward slight angle.
It must slide in at a slight upward angle.
Note: You must install both print cartridges in order for your HP Officejet to work.
“Press OK to print Align page” appears on the display.
7 Press OK.
Oct 06, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Cleaned my all in one, now I have blocked/stuck page rest panels that won't act correctly
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
May 26, 2009 | HP PSC 500 All-In-One Printer
Need basic directions for cartridge installation
Open the Mail upper section of the Printer to expose the print cartriges.....select which print cartridge you want to replace....Either 56 or 57....flip up the lip in front of the ink cartridge and slide out the old and slide in the new (BE SURE TO REMOVE THE PLASTIC COVER FROM THE INK CARTRIDGE).
Mar 25, 2009 | HP PSC 2410 All-In-One InkJet Printer
How to change a cartridge on c4345
Installing new cartridge:
Remove cartridges:
Nov 26, 2008 | HP Office Equipment & Supplies
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 All-In-One Thermal Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
