When I turn on my TV the color is scrambled. Up until now it would clear up after about 30 minutes and the color would be right but today I have had it on several hours and the color is still blotchy. I called a repsir service and they indicated it might be the main board and would cost me about $700.00 to repair. What say you?
  • 2 more comments
  • mhutchiso233 Mar 09, 2009
    THE EXPERT ASKED FOR THE BRAND AND MODEL NUMBER
    IT IS A CYBERHOME FLAT SCREEN 17" CH-HGL 1710
    Thanks.
    Thanks.
    Thanks.
  • 10,594 Answers
Need model and brand of your TV to say any thing.
Posted on Mar 09, 2009
  • Shahid Electronics
    Shahid Electronics Mar 09, 2009
    If it is rear projection TV then most probably it has problem in convergence board. Upon correct info of model and brand, I will check its schematics and will guide you.
    If this TV is under warranty then ask for warranty cover.
    Out of warranty TV should not cost $700 as its near to new TV price.
    I would recommend to call Shop Jimmy for required board as they supply many brands of LCD TV boards on very very low prices.
    Good luck.
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
Have a 5 yr old 50 inch Toshiba projection TV. When turned on, the picture is "scrambled" for 30 minutes and then starts clearing up
Most common problem on Toshiba tv's is the so called nexthyper module thats were your problem is,normaly they have bad ground connections,a tv tech can fix it.
Mar 22, 2010 | Televison & Video
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
- Picture scrambled when set is
The TV has a bad board. It's called the Hyper board. It has been discontinued by Toshiba years ago so it is not an option to replace it. There are some TV repair shops that can rebuild this board by replacing most or all of the capacitors in it. You may want to call your local shop and see if they can do.
Mar 13, 2009 | Toshiba Televison & Video
Mitsubishi #VS-45605
We had a blue cone on the screen. We have adjusted the sharpness, contrast, and cross hairs. The cone has almost completely disappeared, but we still have blue shadows. Could this mean a blown color tube?
Any suggestions would be greatly appreciated.
Aug 13, 2008 | Mitsubishi VS-45605 50" Rear Projection...
1/3 of picture becomes partially scrambled
sounds like you have a frame fold-over fault, does banging the tv have any effect (slightly bang the set on the sides), if it does then its more than likely a dry joint, check all around the frame output chip, hope this is of some help to you
Jun 02, 2007 | Sony KV-35S26 35" TV
TV scrambles
Sounds like from what your describing, a horizontal sync problem and there are a few capacitors in this model that does cause that. If your not a tech this is something you should mess with as the way to trouble shoot this problem would be by using a scjhemetic, a isolation transformer and an ocilliscope. its a possiblity that you could also have a tune rproblem thats giving the sync separator circuit a weak sync pulse from the video its putting out. Good Luck
Jul 31, 2006 | Philips Magnavox MS2530C 25" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
