Question about Canon imageRUNNER 1310 Printer
PAPEL REGISTRA ATASCADO DESLIZAR VIDIO A LA IZQUIERDA
DICE QUE ESTA ATASCADO PERO YA REVISE Y AHORA NO ESTA COGIENDO EL PAPEL
LIZ QUINTANA RAMOS-ASSISTLOG LTDA
5 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
SOURCE: nesecito el diagrama de impresora pixma mp130
hola de donde eres quisiera ver si me vendes tu impresora
Posted on May 22, 2010
alberleu
  • 98 Answers
SOURCE: hola, cordial saludo. soy Eduardo de
trate esta solucion en link de abajo... una vez llege a la pagina click en la solution 2. y siga los pasos que alli dice
http://wsss.cusa.canon.com/wsss/faces/webpage/troubleshoot/troubleshootresult.jsp
espero esto ayude
Posted on Jan 31, 2011
domotek
  • 591 Answers
SOURCE: mi impresora es una canon mx 300 multifuncional
Pardone jo ablo frencais o anglais y un pecito espangol, but what I undrestand is that the printer make a noise when printing??? if that is the case, you should look for debri stuck in the mechanisme (peace of paper) it could also be a worne sway plate gear
hasta la proxima amigo!
Posted on Mar 10, 2011
Tengo una venture 98 hace 2 dias la prendi pero en segedida se apago, solo se quedaba prendida cuando apretaba el acelerador pero ahora ya no, ya la lleve con 2 electricos y nada que puedo hacer
Primero checa la precion de la bomba de gasoline y checa si hay chispa en las bujias y si todo esta normal cambia el sensor de pocicion delaselerador y el map sensor
May 11, 2014 | 1998 Chevrolet Venture
Desconecte una caja doble de dish y ahora uno de los televisores no funciona
Hola Jorge, disculpe la demora en responderle, quizas en este momento ya no necesite la respuesta para este problema pero me gustaria proveerle los detalles de todas maneras por si en futuro necesita ayuda esto le pueda ayudar. Este problema lo puede ocasionar distintas razones. El primer paso a tomar es: Por favor verifique que luces estan prendidas enfrente de su receptor. Bajo donde dice MODE la luz debe de estar en DUAL (2 cajitas) si esta en SINGLE, abra a puerta enfrente del receptor, oprima el boton que dice 'Mode' para poner el receptor en DUAL. Si este no es el proble may esto no lo arregla necesito que en el cuarto del televisor numero 2 (donde NO esta el receptor) usando el control que vino con la TV cuando la compro que ponga la Tv en el canal 60 si tiene una imagen necesito que agarre su control de DISH y en el control oprima el boton de SAT (el cual se encuentra en la parte de arriba a mano izquierda) una vez haga esto, trate cambiar canales. Si esto no funciona, otra vez con el control original de la Tv trate de poner la Tv en el canal 73. Si le sale una imagen, agarre el contriol de DISH, oprima SAT y trate de cambiar canales.
Si lo recien explicado no le funciona, valla a la TV 1 otra vez. Con el control 1 en mano Oprima Menu y una vez tenga el "Menu Principal" en la pantalla Oprima el numero 6, espero dos segundos y oprima el numero 1, espero otra vez dos segundos y oprima el numero 5. Este proceso lo lleva a una pantalla llamada 'Modulator Set Up' En esta pantalla donde dice 'TV 2 OUT' bajo 'Channel' que numero de canal tiene? 73 o 60? Basado en el numero valla al cuarto de TV 2 y usando el control que le pertenece a la Marca de TV (no el control de DISH) ponga la Tv en ese canal. Esto tambien debe de resolver el problema. Si necesita asistencia con su servicio de DISH sientase libre de contactarme a: kimberly.escobar@dish.com
Kimberly.Escobar
Social Media Representative
DISH L.L.C
Sep 22, 2013 | DISH Network 322 DTV Receiver
Mi camioneta tiembla cuando la enciendo o esta parada o voy de recersa, ya le cambie bujias y aceite, y sigue igual, el codigo que me da es el P0302
no especificas que modelo de camioneta es pero con esta informacion tratare de ayudar checa la bujia o el cable numero 2 o tal ves el inyector pero todo indica que es el numero 2 si esto te ayuda asmelo saver solo marca el signo en la esquina de esta nota y si tienes alguna duda proporciona un poco mas de informacion acerca de tu camioneta con gusto te asistire
Feb 26, 2011 | Chevrolet TrailBlazer Cars & Trucks
Porque mi placa se recalienta tanto donde se encuentra el procesador y la tarjeta de video
Hola te recomiendo un sistema de este tipo, ami me pasaba y con esto se soluciono ese problema http://www.bit-tech.net/hardware/cooling/2012/09/26/thermaltake-water-2-0-performer-pro-reviews/1 9ab6aa7c-9dc3-4642-ab5a-d10391656423.jpg
Oct 01, 2008 | Intel D865GBF Motherboard
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Aire acondicionado
tengo problemas con mi aire acondicionado ..al cambiar el filtro...solo tira aire caliente no enfria en lo absoluto
Jul 06, 2008 | 1994 Toyota Land Cruiser
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Canon imageRUNNER 1310 Printer Logo
99 people viewed this question
old marine
old marine
