I'm starting to make some larger prints from my Pentax 6x7 and want to eliminate as much chromatic aberration as possible. Panotools has a "correct" filter that can apply radial shifting of the image to accomplish this. The problem is getting the parameters for the correction. Has anyone found correction parameters for the Pentax 6x7 45mm lens? How about any other Pentax 6x7 lenses? Thanks, -chasfs
Show your appreciation by commenting on pano tools chromatic correction for Pentax 6x7 45mm lens:
Solution #2
posted on Aug 02, 2007
kioner - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
Correcting Pentax 6x7 lenses is specialized territory. However, my tutorial on using Panorama Tools for this purpose may be of some use: #
Of course, scanned film images will respond as well to this technique as will direct digital images. Regardless of what people may say, you *can* improve this aspect of image quality (along with distortion) even after the image is on film.
Brian #
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
paulrmc - usenet poster
On 19 Nov 2004 17:01:46 -0800, (ChasFS) wrote:
While I don't have CA problems on my P645 lenses, I sometimes have them with my 35mm setup. I gave up trying Panotools (too difficult to achieve a proper R/G and Y/B parameters set), but I found "Debarrelizer", a shareware plugin from The Imaging Factory, very useful. It has sliders for CA compensation. Quite effective with the typical R/G and Y/B color fringing. Can do nothing for scanner-induced purple-fringing and other CA-related artifacts, but it's quite better than nothing. :-) By the way, it can do defishing as well (as the name implies).
Fernando
Solution #4
Jimmy NY - usenet poster
In color imaging, CA in the lens results in color fringes, red to one side/blue to the other, at high-contrast edges in the corners of images. The worst visual aspects of this can be cleaned up quite nicely, resulting in images that are quite usable where there had been disturbing color artifacts before.
It's a useful, well-known technique for direct digital capture. I'd think it would be a bit harder to take advantage of in scanned MF, but it's worth looking into if you have that problem in your images.
David J. Littleboy Tokyo, Japan
Solution #5
Ranny - usenet poster
Do you know what chromatic abberation is? It's in the camera & lens. You aren't going to recapitulate detail that is not on the image plane. I suggest you find what it is about your images that is bugging you and fix it in the camera (learn how to take a picture), and if you cannot, then move on - or dither yourself to death with digital nonsense.
