Question about Hotpoint Aquarius WF000 Front Load Washer
Display lights flash
After taking in water the motor turns as normal and then stops the power light flashes rapid and the rinse hold light flashes slowly then the pump emptys the drum
  • 20 Answers
Hi Adam, Try checking the door lock mechanism and it's related components, I am sure the fault lies somewhere around there.
You can do it mate, keep on trying.
Posted on Mar 10, 2009
I have just posted the same problem about the lights flashing rapidly, I have just gone to investigate my machine and switched it off and on again at the mains and so far it has resolved the problem. Hope this works for you.
Posted on Mar 09, 2009
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
Indesit WIXL143 stops part way through program
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Mar 21, 2010 | Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
2005 honda odyssey homelink programming
If you just received your vehicle and have not trained any of the buttons in HomeLink before, you should erase any previously learned codes before training the first button. To do this, press and hold the two
outside buttons on the HomeLink Transceiver for about 20 seconds, or
until the red indicator flashes.
Release the buttons, then go to step 1.
If you are training the second or third buttons, go directly to step 1.
1. Unplug the garage door opener motor from the electrical outlet.
2. Hold the end of the garage door opener remote 2 to 5 inches from HomeLink. Make sure you are not blocking your view of the red indicator in HomeLink.
3. Press and hold the remote transmitter button and one of the HomeLink buttons at the same time.
If the red indicator in HomeLink begins to flash slowly at first, then rapidly, release both buttons, and go to step 5. If the red indictor in HomeLink continues to flash slowly (does not flash rapidly), your remote transmitter may stop transmitting after a short time. Go to step 4.
4. Press and hold the remote transmitter button and one of the HomeLink buttons at the same
time. While continuing to hold the HomeLink button, press and release the remote transmitter button every 2 seconds. If the red indicator in HomeLink begins to flash slowly at first, then rapidly, release both buttons, and go to step 5. If the red indicator in HomeLink continues to flash slowly (does not begin to flash rapidly), repeat steps 2 thru 4.
5. Plug in the garage door opener motor, then test the HomeLink button by pushing it for about 1
second. If the button works, programming is complete. If the button does not work go to step 6.
6. Push and hold the HomeLink button for a few seconds, then watch the red indicator on HomeLink.
If the indicator stays on or flashes slowly, repeat steps 2 thru 5. If the indicator flashes rapidly
for 2 seconds then stays on, you have a rolling code transmitter. Go “Training with a Rolling Code System”
7. two HomeLink buttons to operate any other compatible remotely controlled devices around your
home (lighting, automatic gate, security system, etc.).
Repeat these steps to train the other
Jan 05, 2010 | 2006 Honda Odyssey
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Water tank light is flashing with main heating light
HI
I don't think your machine is finished descaling. Follow these steps.
With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz’s. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don’t turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and your ready to go.
Apr 13, 2009 | Solis Palazzo Espresso Machine
Hotpoint Aquarius WF000 Front Load Washer Logo
281 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
