Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool refrigerator side by side ED5SHAXMQ10
Ice Maker just stopped working one day. Infra-red seems to be working ok. Put cell phone camera in front of eye and light is flashing.
Door water and ice dispenser work fine. Temp in both freezer and refrigerator are fine.
No water goes into Ice Maker and no motor activity is detected.
  • jbs1156 Mar 11, 2009
    ice maker stopped working
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
SASSYBEAR
  • 148 Answers
SOURCE: Whirlpool Side by Side Refrigerator Wont dispense ice
if you lift out the ice bucket you will see the "gear" that turns the auger. The gear is metal but the part on the bucket is plastic and this can become stripped out. Also check that there is not ice frozen around the bottom of the bucket where an ice cube may have lodged the chute door partially open and melted some of the ice in the bottom creating a blockage.
Posted on Nov 11, 2008
Sea Breeze
  • 4655 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
No Ice is being made
Ice maker solenoid ...side..water side ok replace
Aug 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice-maker stopped working9whirlpool side by side) infra eye seems ok
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
ii
Jun 22, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker won't work
yes ,,, i found quit a few to be bad ,,, if you have done all the other things thats all left ,,,, replace them and allow 24 hours for ice to drop / larry
Dec 01, 2008 | Whirlpool GC5SHEXNS Side by Side...
Refrigerator Whirlpool Gold Conquest (Side by side)
the ice maker is of a poor design. There is a wheel that essentially is the mechanical timing device of the icemaker. The shaft in the wheel is of poor design and it breaks leaving a non-functioning useless ice maker. Whirlpool does not sell the wheel & shaft assembly - you have to virtually buy a new icemaker. Takes about 10 minutes to replace. Charge for the part = $107; charge for the labor = $175
Aug 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool icemaker not making ice
optics would not gon bad from frozen water, strictly a computer watching ice level in ice bucket. it should however be lit blinking at least, if it set ot on positoin and no indicator light is on at all sounds like a bad emiiter/ reciever.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not making ice.
the infa red sensor should be on constant if the switch on the right is in the on position, if the ben is enpty
if the ben is full the beam will flash interpting the ice maker from making ice untill the level of ice drops down below the holes in the bin then it will make ice again
beam part number if needed is4389102 it comes as a kit with the emitter and reciever boards
Dec 28, 2007 | Whirlpool ED5SHAXM Side by Side...
Ice maker is not working but water dispenser is.
check you havent put icemaker onto vacation mode.. also if it has infra red sensors at both sides of ice maker unit , these can go faulty.. ally
Jul 02, 2007 | Whirlpool ED5SHAXM Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
469 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
