Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
I forgot my password and user name for my belkin54g router so what i can do for i can reset the old user and password to a new one
  • 43 Answers
If you have the documentation on this router you might be able to default the router to its factory settings and access the router with the default login/password.
Posted on Mar 10, 2009
Belkin54g password
Just user:Admin no password or password=password.Or RESET the router.
Jul 14, 2013 | Gateway Belkin 54g Wireless DSL/Cable...
Forget user name and password how to set up new ones
You may have to resent the router for that purpose! User name and password are usually default for each router. If you have not set up a user name or password try default admin in password section and leave user name blank. If you have set up a user name and password and forgot now then you may have to reset the router by pressing reset button on back of router for 30 to 60 seconds which brings back factory default settings for the router!
Sep 12, 2011 | Computers & Internet
Forgot user name and password need to add new
Sorry but this is the only to reset the password
Press the Reset Button for approximately 10 seconds
Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
Jun 06, 2011 | Linksys Wireless-G WRT54G Router
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
Is there a way to reset the password to the router? I recently bought a new computer and need the password for this laptop. I forgot the password to the router that was programmed to my old laptop. Thanks
sure..in back, is a small hole that takes about a paper clip wide probe. press for 10 seconds while powered up. Then it resets to admin admin(user name/password). then access it through 198.162.1.1 on browser. should do it.
Dec 02, 2009 | Linksys Wireless-G WRT54G Router
Forgot username and password how do I fix this westell 327
Did you forget the user name and password for accessing the Web Utility of the router? If yes, you need to reset the router back to it's factory state. There's no other way but to reset it and then reconfigure the router. Set a new user name and password.
Regards,
Firesnake09
Aug 15, 2009 | Westell Wirespeed VersaLink...
Password for belkin54g
only type admin in password nothing in user name. Otherwise reset and do the above, it is the default.
Aug 14, 2009 | Computers & Internet
I cannot set password
There are 2 users in this router, 'admin. and 'user', default password is blank. admin can change password of user without having old password, user can change his own password, admin can change password of his own by supplying his old password then new password twice. To log in to this router, default address is http://192.168.0.1 user name admin and password blank. You may now change password from tools menu.
If you forgot user password then log in as admin and change password, If you forgot all password then only way is to reset router from rare pin hole. Pressing reset for 20 seconds.
Jul 15, 2009 | D-Link AirPlus DI-524 Wireless Router
I'd like to add the new notebook to my network.
You will need to reset the router to factory by holding in the reset button if you don't have the password. Before you do that, however, you will need your user name and password to re-configure and connect to the DSL provider. When you configure the wirelss network settings, write down your wireless password which should be different from the password you create to log in to the router.
May 17, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Looking for the general password for the belkin54g
@boblawrence6
Read page 14 from the users manual to reset the custom password & other settings.
Users manual at > http://www.belkin.com/support/product/?lid=en&pid=F5D8233-4
find the default Password at > Page 24 and reconfigure your router settings.
@munchx3mom
Surf to > http://www.belkin.com/support/product/?lid=en&pid=(CHANGE THIS WITH YOUR PRODUCT ID) *F5D8233-4*
Best regards
Screbilde
Jul 20, 2008 | Belkin (F5D7231-4) Wireless Router
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
363 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
