Question about Canon PowerShot S51S Digital Camera
Folding screen back to compact position the screen goes blanK.
I can view photos nomally with flip screen extended out but if I want to fold it back and view in compact position the screen goes off and transfers to the view finder. I know this happens with screen folded away but this has always worked before if I want to have it in a compact mode with display screen available.
    Brigadier General:
  • 5,158 Answers
Go to the options menu.... there should be a setting to restore defaults ... or to change the view screen
Posted on Mar 09, 2009
  • Canon Master
  • 19,396 Answers
Try to reset the camera to factory settings from the settings menu.
  • Ginko
    Ginko Mar 09, 2009
    You can also reset the camera to factory holding the Menu button for 10 seconds, until the menu asking if you want to reset the camera comes up.
    If resetting to factory does not work, then the problem is a defective screen folder switch.
My brand new stapler suddenly stopped folding the staples. It just shoots out singles; good for bulletin board posting-not for stacks of papers. Can this be fixed?
The item on the bottom that folds the staples has two positions. Press it up from the bottom and swivel it 180 degrees to folded staple setting.
May 13, 2016 | PaperPro Compact Stapler, 15-Sheet...
Wing mirrors keep folding out and wont stop, why? can't find a relay that controls this
Outside Mirror May Fold Out to Far : BMW 328i Common ...
repairpal.com > Problems > BMW > 328iside mirror fold out too far . and how to reset to normal . thanks. Upvoted .... side view mirror keeps folding out in a very extended position when I hit unlock.
Sep 20, 2015 | Cars & Trucks
On a 207 G6 GT Pontiac retractable hardtop where is the sensor that gives the message top not secure. Top goes up and down seem secure will not allow the trunk to open with the key or door button
The retractable hard top is controlled by the folding top control (FTC) module.
Power Folding Top System Components
The power folding top system consists of the following components:
The folding top control (FTC) module
Hydraulic pump assembly; valve 1, valve 2 and motor
The hydraulic lines and the cylinders
GMLAN communication to the Body Control Module (BCM)
Open/Close request circuit to the driver and passenger window motors
Power and Grounds
Folding Top Main Power Fuse 30A
Folding Top Logic Power Fuse 20A
Ground G301 for the FTC module and G305
Folding Top Open/Close Switch (S15 and S16)
Rear Compartment Limit Switches
Rear Compartment Lid Release Switch (S3 and S4)
Rear Compartment Lid Release Switch-Front Hinge-Left (S11 and S12)
Rear Compartment Lid Release Switch-Front Hinge-Right (S9 and S10)
Folding Top Front Location Pin Guide-Left (S17 and S18)
Rear Compartment Lid Release Switch-Left (S19A)
Rear Compartment Lid Release Switch-Right (S19B)
Rear Compartment Partition Position Switch (S20)
Folding Top Front Location Pin Position Switch (S13)
Folding Top Front Latch Actuator Position Switch (S14)
Hall Effect Sensors
Folding Top Header Latch Cylinder Sensor (S1)
Rear Compartment Cylinder Extended Sensor (S2)
Your best bet is have the system checked for DTC'S - diagnostic trouble codes ! If it showed a message top not secured there is a DTC stored in the control module ! there are 24 possible DTC'S
May 29, 2015 | 2007 Pontiac G6 GT
Graco alano not folding? the push and twist handle not turning?? so the stroller does not collapse or fold. how can i get it to fold. wife needs to travel back and i am not sure airline would allow her if...
Took a while but finally figured it out. Original thinking was that the problem is in the handle twist and release mechanism. The problem actually lies in the collar where the unit locks into place. If the stroller is in the open position it can't be fixed unless it's folded up. To open stroller without the twist handle -- locate both black spring loaded collars where it locks into place (approx outside where the seat and seat back meet). Manually pull both the collars up the shaft. The spring is tight and it may take an extra set of hands to get the right leverage. Once the unit is in the folded position -- flip the stroller upside down and blast WD-40 into the hole where the spring pins are and work the black collar up and down. The twist mechanism on the handle will now work. My daughter claims it didn't even work that good when the stroller was brand new and we saved the time and trouble of shipping the entire stroller and seat system back to Georgia just to let the Graco people decide what to do. Bottom line is that this mechanism design stinks from the get go. Hope this helps.
Oct 12, 2012 | Graco Alano Travel System Stroller -Greer
When i fold my g12 screen, turns into blank.. works fine if is folded out. any ideas?
There may your LCD connecting flip is defective, just replace it and camera will be fine.
Aug 29, 2012 | Canon G12 Digital Camera
I have purchased Dell Inspiron 14'' model Laptop. the problem is related to bending/folding of screen. It becomes blank (not responding/ off mode) when i move the screen to close my lapy, at a certain
There is a switch in the hinges that shuts off the display when the lid is closed to a certain point. It is to reduce heat and extend battery life. It is working as it should do.
Nov 18, 2017 | Dell Inspiron 14 Laptop Computer (Intel...
What is a Folding Bicycle?
A folding bicycle is a bicycle that folds for convenient storage and portability. The perfect folding bike would be one that rides as well as a quality full-size bike, folds in seconds, weighs less than 10 kg (22 lb), and folds small enough to fit under a bus or train seat.
Dec 16, 2010 | Cycling
2003 gmc mirrors do not fold in
The power mirrors are controlled by a module (computer) DDM - drivers door module an the PDM - passenger door module .
Folding Mirror System
Folding Mirror System Controls
The folding mirror system requires signals from 2 separate switches. The mirror select switch must be in the neutral/fold position and the mirror direction switch must be activated to the left/extend or right/retract positions. Both switches are integrated into the DDM and provide direct signals.
Folding Mirror System Operation
Upon receipt of the required switch inputs the DDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function. The DDM will also send a class 2 message to the PDM indicating the requested function. The PDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function.
Power Mirror System
Power Mirror System Components
The power mirror system consists of the following components:
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
DTC B1722
The driver door module (DDM) and passenger door module (PDM) switch the mirror fold motor control circuits to battery voltage and ground in response to mirror extend or retract command.
Apr 06, 2017 | 2003 GMC Yukon XL
Bugaboo Frog Stroller (Folds on it's own)
Don't worry, this is normal. Once you lock the seat into place, the front bar stays put, even if you hop a curb.
Mar 23, 2008 | Bugaboo Baby Gear
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
Canon PowerShot S51S Digital Camera Logo
24 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
