Question about Fellowes S701CM Shredder
Fellowes S701CM Shredder.
When I plug in the power, the unit does not operate.
  • 58 Answers
You can check the switch out by spraying some WD-40 in it, that clean the contact in side the switch
Posted on Mar 29, 2009
Why do my fellow ds-3 shredder not turn on?
http://assets.fellowes.com/manuals/DS-3%20Manual_1L_2010.pdf
Check and make sure the receptacle where it is plugged in has current. Unplug the cable and then plug it back in. You have an Over-ride switch on your unit, try it. If it still does not work you will have a power supply problem.
Aug 18, 2014 | Fellowes 3231001 8-Sheet Ds-3 Deskside...
How to open fellows s701 cm shredder?
There are six Phillips head screws around the perimeter of the underside, plus one more hidden screw in the center under a label. Then the cover just lifts off ...
May 18, 2014 | Fellowes S701CM Shredder
There seems to be a power ise when switch ingages breaker shuts off
I own a Fellowes PS 60 shredder.
I DO NOT THINK THE LINK WILL HELP YOU, BUT AT LEAST YOU WILL HAVE IT.
I advise you NOT to use your shredder if it is causing the cicuit to shut off_it may start a fire!
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jan 11, 2014 | Fellowes Powershred PS-60 Shredder
How doyou remove the top to a fellowes s701cm shredder
Remove the six obvious screw around the perimeter of the underside, plus one more screw in the center that's hidden under a label. Then cover will just lift off.
Feb 02, 2012 | Fellowes S701CM Shredder
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
Mar 27, 2011 | Fellowes Powershred PS-60 Shredder
Overly loud shredding; stops prematurely
I have taken many shredders apart and found them so clogged up with shreds of paper and too much oil will turn into paper mud.Be bold and take the top off and clean it out. Unplug the power source and when removing the top , be careful because their will be a short cable connecting the top to the circuit board. Easy to damage.
May 12, 2009 | Fellowes S701CM Shredder
Fellows S701CM shredder won't respond
unplug in and check the fuse in the back side of the shredder
good luck
Jan 24, 2009 | Fellowes 3011001 Shredder
Royal Shredder
there is a small micro switch in about the middle of the paper slot, make sure it is not jammed, it should move freely and make a small clicking sound with the power off.
Jan 26, 2007 | Fellowes S701CM Shredder
Fellowes S701CM Shredder Logo
414 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
