Question about Jenn-Air JJW8130D Electric Single Oven
5 yr old Jenn Air Electric oven won't maintain oven temperature
For example, if I preheat the oven to 350, I notice that the food is not cooking. When I turn it off and set it to preheat again, the oven will read that it is 320 degrees. It does not maintain a consistent temperature.
  • joe in NH Mar 28, 2009
    my 4 1/2 yyr old jenn-air songle electric 30" wall oven with convection will not come up to the selected temperature. If we set it for 350, it never gets hotter than 275?????
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Posted on Oct 23, 2009
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Oven won't hold temperature.
    If oven is electric pleace check that the heating elements are ok, could be that only one or two elements could be the only heaters hence luck power to maintain temparature when open or gets too slow to preheat.
    Aug 03, 2015 | Ovens
    Is it dangerest when your oven beeps f2
    Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
    Jan 13, 2012 | Stoves 600GR Gas Single Oven
    Oven temperature fluctuates.Oven heats to correct temp on preheat, but as the food cooks the temperature drops.
    If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
    Oven Problems Electric Oven is Heating Slowly or Poorly
    heatman101
    Nov 17, 2010 | Frigidaire Ovens
    7 yr old jenn-air wall oven locked shut, shut down
    It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
    Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
    Seems to be taking a long time to cook
    To preheat oven just select the temp you intend to cook at and wait until the red light goes out,it is then preheated
    Then you can put your food in and carrying on cooking.
    Yes you do put it on fan symbol, but make sure it is on the right one , as some ovens have fan only as well as fan and heat.
    Plz rate this solution.
    thanks.
    Dec 14, 2008 | Ovens
    Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
    I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
    Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
    1. Intermittent oven temperature sensor or wire harness or,
    2. Intermittent contact on power relay board"
    This doesn't help since it is too technical. What should I do next?
    Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
    Amana Convection oven not controlling temp
    I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
    Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
    Jenn-Air JJW8130D Electric Single Oven Logo
    934 people viewed this question
    Top Jenn-Air Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Craig Butler
    Craig Butler
    Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
