Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
F&P E442B - Knocking/cracking noise
Loud knocking/cracking noise when fridge is running, only way to stop it is by opening fridge door. I've checked that both fans are working and not iced up.
  • 2 more comments
  • Anonymous Mar 14, 2009
    I have the same problem how to solved this? there is is the cracking anoiying sound :-(
  • Anonymous Mar 30, 2009
    CRACKING SOUND FM FRIDGE QUITE LOUD - ANNOYING
  • Anonymous May 01, 2009
    Bloody noisey cracking in the middle of the night
  • howardg1293 Jul 02, 2009
    Thanks, but when i checked the condensor it was free of ice, has been knocking now for 6 months, looks like it will do it ongoing, i thought it might have settled down
It is probably the buildup of ice around the condensor (located behind white panel in freezer). I chekcked mine and the ice had pushed the panel oajar and the condensor unit was out of place too. All due to the excess buildup of ice. I removed the ice tonight.. will tell you if this fixes noise problem. Also our fridge was not cooling ..freezer ok.. hope this fixes this problem too- otherwise i'll test the fan (located behind panel in freezer compartment.
Posted on Jun 28, 2009
  • 400 Answers
You need to make a vacuum breaker, break a lollipop stick in half and attach to the gasket at the bottom of the fridge door, that should sort it.
Posted on Mar 10, 2009
We had the same problem with our Whirlpool side by side and it turned out that the water line was knocking on the back of refrigerator; so my husband covered it with the round form tubing and Quiet. Try it.
I have encountered another problem just last night - while cleaning my refrigerator I noticed that on the ride side of the internal wall of my refrigerator is cracking. Does anyone know if there was a recall or is there coils running inside this liner. I called Whirlpool and I have to call tomorrow and give them my serial and model number. But then I chatted with a person online from whirlpool and he said, unfortunate nothing we can do it will be a sore eye...I don't think so I told him after spending a couple thousand do you thing I will take this attitude from you. That is when I called their Corporate office in Michigan. Our refrig is just turning 7 years old and I have had refrigerators that have last 15 plus years. Something is just not right.
Posted on Jan 03, 2012
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
Knocking rattling noise from engine appeared while driving loss lil power running but loud knocking in engine
You didnt state vehicle however if the engine knocks the knock sensor will back off the timing thinking its detination not an actual knock if its knocking loudly stop driving it, something is going to let loose
Oct 06, 2015 | Cars & Trucks
Enfine noise
Could be many things. What kind of noise? Knocking, ticking, or just plain loud? Loud could be loose exhaust manifold, cracked manifold, bad exhaust gasket, bad exhaust pipe, ect. Knocks and ticks, squeals and more are different story. If you can't describe it, post a video.
Jun 02, 2014 | 2007 TVS XL Super HD
Continuous knocking noise from ice maker. Ice maker has been off for past 3 months. Only thing that will make it stop is turning it off or unplugging it.
Hi Marcel,
Thank you for contacting fixya.
Our ice maker recently had its water inlet freeze up, preventing water from filling the trays. The mechanism kept dutifully trying to push nonexistent ice cubes into a bin that never filled up, which might account for the knocking noise in your case.
To defrost it we just unplugged the unit, took all the food out of the freezer section, and left the door open for a couple of hours. It wasn't long enough for any of the frozen food to defrost, and since we were careful to minimize opening the refrigerator section's door, the food in that part stayed cold enough to be safe as well.
Feb 09, 2014 | Frigidaire FPHB2899LF
Loud knocking noise engine
Air inlet or outlet may be clogged, check air filter and catalytic converter, as possibles!
Jan 17, 2014 | Chevrolet Malibu Cars & Trucks
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Fridge making knocking sound, only stops when fridge of freezer door is opened.
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Jan 23, 2011 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
1,720 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
