Question about Megatronix - PASSLOCK-SL2 - GM Passlock Data Bypass Kit - Self Learning Byp
Help! 2007 chevy impala stuck in park and the key wont come out.
I have a 2007 chevy impala that is locked up. AIt will not go into any other gear. it is not the transmission. the key won't come out ofthe ignition either. i think it had t do with some type of theft protection.
DAD5bbbbg
  • 111 Answers
SOURCE: My chevy Trailblazer is stuck RUNNING,My ignition wont turn off?
Try to move the steering wheel back and forth. If that don,t work try to disconnect the neg - side of the battery. this will at least kill the engine.
Posted on Mar 03, 2009
  • 8 Answers
SOURCE: My 2006 Chevy cobalt key will not turn completely
ur gear shift has a little plastic bar on gear shift and it has crack on the side u cant see have it changed out and both of ur problems will be solved at same time.
Posted on Jul 07, 2009
adve1958
  • 246 Answers
SOURCE: 2005 Chevy Impala ignition switch stuck in off position
if it doesnt turn you have a worn out ignition cylinder, the only fix is to replace it, Code the ignition lock cylinder, if necessary
CAUTION:Perform the body control module (BCM) theft deterrent relearn procedure whenever you replace the ignition switch lock cylinder.
Posted on Sep 08, 2009
  • 36 Answers
SOURCE: gear shift stuck in park and can't push in the
this is a shot in the dark since could be many things, but check the brake light switch, you have to put on brake to shift from park, had this happen on a ford ranger once, the switch worked under light pressure as far as lights were concerned but required heavy pressure to shift
Posted on Oct 26, 2009
Mike258
  • 1498 Answers
SOURCE: how do you change a lock n key ignition switch on 1998 chevy 6 cy
STOP. STOP. STOP.
I WILL POST WITHIN THE HOUR.
In the meantime, click here for a few things you need to know before even considering working with undeployed airbags.
Mike
Posted on Nov 04, 2009
How do I remove a key stuck in the ignition of a 2006 Chevy Impala?
KEY WILL REMAIN IN IGNITION LOCK UNTIL CAR IS IN PARK FULLY. PERHAPS THE CABLE TO THE SHIFTER IS TO BLAME
Apr 09, 2015 | 2006 Chevrolet Chevrolet Impala LT
Keys locked in 2007 chevy impala
stick a straightened metal coat hanger in between the door and the vehicle and fish for the unlock button. this is made easier by prying the upper part of the door open slightly with something that wont scratch the paint like wood or plastic.
May 21, 2014 | 2007 Chevrolet Impala LS Sedan New Cars
Car will not go out of park gear
Fixed for 35.00.. same thing to my 2007 impala.. locked in park.. can't remove key.. dealer wanted more that 500.00 to repair when part is 35.00.. the wire in gear shift breaks.. second time for me with only 30.000 miles.. the part can be ordered or get at dealer..
Video shows how its fix..worked great now
http://www.youtube.com/watch?v=9v64eNMZQ1g
Apr 04, 2014 | 2008 Chevrolet Impala
2009 Chevy Impala key stuck in ignition
Electronic Park Lock (EPL)/Ignition Lock Cylinder Control Actuator: If the vehicle is equipped with automatic transmission and a floor mounted console gear shift, it has an ignition lock cylinder control actuator system in the steering column. The ignition lock cylinder control actuator purpose is to prevent the ignition key from being turned to the OFF position when the transmission is in any position other than PARK and the vehicle may still be moving. The column ignition lock system consists of an ignition lock cylinder control actuator, and a park position switch that is located in the automatic transmission shift lock control switch. The ignition lock cylinder control actuator contains a pin that is spring loaded to mechanically prevent the ignition key cylinder from being turned to the lock position when the vehicle transmission is not in the PARK position. If vehicle power is lost, and/or the transmission is not in the PARK position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column.
Does your impala have floor shifter ?
Jan 31, 2018 | Chevrolet Cars & Trucks
My 2008 Chevy impala will not come out of park
The
shifter needs to be inspected. Its quite possible that The
shifter assembly is got misaligned, it has to be open and realign.
There
are many other possibilities. But if it was working right up till now and
suddenly this shifting problem occurred then its shifter
assembly alignment issue.
Also
i suggest you to refer these gear shift issues, which are mostly noticed. These
are direct links with appropriate solutions to
the specific problems of gear shift
GEAR SHIFT ISSUES
Gear
indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of
Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high
gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won\'t downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Buick Park Avenue: Transmission will
Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won\'t shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while
driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
How do i get my gear shift unstuck on a 2007 chevy impala?
it should work off the brake if you push on the brake and it dose not unlock could be a number of things lets start with the switch at the brake peddle look under dash for push buttons that work off the brake peddle and make sure they have not come loose.
Aug 01, 2012 | MagnaFlow 2007 Chevy Impala - SS, 5.3L V8,...
2007 chevy impala Shifter stuck in park
Do you have brake lights? The brake switch on the pedal has to work to send a signal to a solenoid at the shifter to release park.
Dec 04, 2011 | 2007 Chevrolet Impala LS Sedan New Cars
The gear shift is stuck in park in a 2007 chevy impala. The button the gear shift will not press in to let it shift into reverse or drive. Any solutions?
I went to get in my car tonight to leave and my console gear shift would not shift out of park. The gear shift button will not press in. Absolutely nothing! I have a 2007 Chevrolet Impala. Anyone know of this problem and what is the solution?
Nov 26, 2010 | 2007 Chevrolet Impala LS Sedan New Cars
2007 chevy impala will not turn off complety, in p...
chevrolet has this problem frequently on this model car and there is a service bullentin;in which,you can possibly get this repaired for free.check your computer for this particular bullentin and call your dealer.If no luck there's several possible causes of this problem and solution's.pull your console and check for broken wire's to your shifter lock solenoid and repair these wires if broken,the problem is that your ignition responds to your shifter and lets it know that you are in park and safe to get out of your car.If the shifter doesn't go all the way in park then the ignition wont completely dis-engage.It's also possible that you have a bad ignition switch.check for stuck boot on your shifter lever,some would say replace your entire shifter mechanism,but that may not be your best solution!!
May 20, 2010 | Megatronix - PASSLOCK-SL2 - GM Passlock...
Shifter stuck in park!
you have to take off the plastic all around the gear shifter. You can wedge a screw driver carefully around the edges and pry the plastic off then there is a screw on the shifter take that off and slide the top off and then take off the rubber until the whole shifter is exposed then you will see in the cavity on the right side a little metal round tab on a spring that you have to push in with a screw driver and it will release the shifter. Good luck
Jan 19, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
Megatronix - PASSLOCK-SL2 - GM Passlock Data Bypass Kit - Self Learning Byp Logo
794 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
