Question about Home
I brought a whirlpool tub 4 years ago. I was
I brought a whirlpool tub 4 years ago. I was remodeling and had the tub moved from its location. The worker damaged the plastic tubing that the water runs through. How can I fix that? Is it expenses? Thank you. Jacqueline
    Problem Solver:
  • 6 Answers
Hello Jacqueline,
not not really an expensive job since the tub is out already, you shouldn't pay more than 100.00 dollars for this type of repair.
Posted on Mar 22, 2009
I have a 14 year old Aker whirlpool tub. During bathroom remodeling, I found a leak where the pipe comes out of the jet. I could not repair it. Are the jets available yet? I found two numbers on the...
Jet bodies match only the jet trim that goes with them. These are a set and are not interchangeable with other models or brands of jet. Each Bath Part in unique in subtle ways only.
In order to find the correct jet body you need to match up the face of the jet trim to what is shown online. Once you know that brand of jet trim we can find you the correct jet body.
I would invite you to search our site at US Parts Center and see if you can find the jet face that you have.
Once you do we will be able to match up the correct jet body for you.
Rod
US Parts Center
888-521-6183
Jan 15, 2013 | Whirlpool Royal A-909 Bathtub
Our jacuzzi tub is 20 hrs old and possibly is leaking. About 6 mths ago we remodeled bathroom &replaced all tile around tub & shower. We do not want to tear out tile. What would be best way to pin...
if you have a water stain on the ceiling below your tub then you have a water leak. There is no easy solution for this. You must get to the underside of the tub in order to watch the jets when the tub is full of water to isolate the leak and then have it repaired by a plumber.
Aug 15, 2011 | Jacuzzi Home
Remodeled kitchen axly 4 years ago. Whirlpool MT2145SJ (number taken from use and care guide) microwave installed above range. About month or so ago, the fan quit running during the microwaver time, and...
Hello, unfortunately we are not trained technicians and we cannot advise you how to repair the unit. We would always recommend resetting the appliance by removing the power for 2-3 minutes. If that does not correct the problem we would suggest having a certified technician properly diagnose the problem that you are experiencing. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased your appliance to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 18, 2017 | Whirlpool MT2145SJ 1100 Watts Microwave...
12 year old fiberglass tub originally white, now
home depot sell a bath tub remodelation kit.
it cost about $40 .
May 12, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Can not get the jets to work
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Dec 02, 2009 | Home
One piece fiberglass tub cracked in the middle of basin (4'' crack
The only sure fix is to drill holes in the bottom of the tub and shoot in a commerical grade low expanding foam to fill in the void. The foam you find a Lowes or Home Depot will not work as it is a high expanding foam and will ruin your tub. Call a reliable tub repair company experienced in this type of repair. It should not exceed 200.00 including rolling in a new floor.
Mar 05, 2009 | Home
Bathtub caulk turning dark color in spots?
Ibelieve it is mold and the best thing to do unfortunately is re caulk it but use amold resistant caulking(kitchen and bath dap)
Feb 01, 2009 | Home
New bathtub chipped
You should ask a lawyer for advice on who should fix it, but there are kits available to patch chips like those. You apply it as a liquid and then wet sand it. They are fairly easy to apply, and inexpensive.
Dec 22, 2008 | Kohler Archer 5ft Whirlpool with Comfort...
Just moved. New washer leaks water and appears tub is off center
CHECK THE BALANCE SPRING LOCATED (INSIDE LEFT REAR OF MACHINE). IF SPRING IS OFF IT CAN CAUSE THE TUB TO TILT TOWARD THE FRONT AND THE TUB FILL HOOD WILL NOT BE OVER THE TUB DURING FILLING OR THE TUB WILL BE ERATIC DURING THE SPIN WHEN RINSE WATER IS SPAYING IN CAUSE ING THE WATER TO MISS THE TUB AND SPRAY OUTSIDE. THIS IS COMMON IF THE UNIT HAS BEEN MOVED OR PLACED ON IT'S SIDE OR CARRIED AT EXTREME ANGLE.
Jan 17, 2008 | Whirlpool LSN1000LW Top Load Washer
Home Logo
80 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
