Question about Dell Inspiron 1525 Laptop Jet Black (15.4" Wide Screen with true life, built-in Webcam, Intel Pentiu... PC Notebook
The system starts well but after some times it would not respond to anything (mouse or keyboard) except the shut down button
    President:
  • 2,653 Answers
Boot the computer into Safe Mode with Command Prompt.
Press F8 every few seconds as you start the computer.
You'll see a list.
Choose the one I mentioned above.
Once you're able to get to this point, let me know
and I'll take you to the next step.
Posted on Mar 09, 2009
The Mouse and Keyboard are frozen and will not work. Pressed unlock mouse button but did not respond. What do I do?
Restart by pressing the Start button and keep pressing until it shuts down. Then restart.
Here is more on this subject:
http://www.computing.net/answers/windows-xp/hp-pavilion-is-frozen/162636.html
Jan 07, 2011 | HP Pavilion dv9000z Notebook
My hp wireless keyboard and mouse doesnt work
Hi, these instructions will help you, and "everything that you do for the Keyboard; apply the same instruction to the Mouse." First, click on the "Start" button, in the ["Start Search Window], Type: keyboard; the "Keyboard" Properties window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (check, the Keyboard Status). "Update the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; "Uninstall the Keyboard. To "Uninstall the "Keyboard," do the following: Shut-down (turn- off completely); disconnect all the Keyboard Devices that are connected to the Computer. Next, turn-on the Computer, and go back to the "Keyboard Properties," next, click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the Computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the Computer. "You will repeat exactly what you did from the start, this will "Re-install the Keyboard. "Restart the Computer again after all changes have been made; this will ensure the changes take effect properly. "Rating the solution will let me know if it worked; or you may need further assistance, thanks."
Jun 19, 2010 | HP USB Wireless Keyboard/Optical Mouse...
I've tried several times to get this wireless mouse and keyboard
  • Hi, these instructions will help you, and "everything that you do for the Keyboard; apply the same instruction to the Mouse." First, click on the "Start" button, in the ["Start Search Window], Type: keyboard; the "Keyboard's" Properties window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (check, the Keyboard Status). "Update the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; "Uninstall the Keyboard. To "Uninstall the "Keyboard," do the following: Shut-down (turn- off completely); disconnect all the Keyboard Devices that are connected to the Computer. Next, turn-on the Computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the Computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the Computer. "You will repeat exactly what you did from the start, this will "Re-install the Keyboard. "Restart the Computer again after all changes have been made; this will ensure the changes take effect properly. "Rating the solution will let me know if it worked; or you may need further assistance, thanks."
Jun 12, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Mouser curser not responding.
try it in safemode
just before windows starts press f8 a couple of times.
Select Safe mode
see if the mousse works there.
If it doesn't then it's probably a hardware failure. get another mouse.
If it does work then some setting is mess up in windows.
while in safemode goto control panel- system- device manager
in device manager delete the mouse profile and reboot
Oct 09, 2009 | Computers & Internet
Mouse Stops Responding
You need to reset the mouse and keyboard to the sensor. On the sensor(base) you should have a button and under the mouse you should have also a button. Press the sensor(base) button first and quickly the one under the keyboard and mouse. If the doesn't work shut down the system, unplug the mouse and keyboard sensor(base) and re-plug it back in . Start the system and try the process again.
Oct 03, 2009 | ViewSonic ViewMate CW2206 DHCW2206...
Logitech MX 600 mouse - left side not clicking
Try holding both buttons down, switch off, switch on. Worked for me.
Sep 09, 2009 | Logitech MX 600 097855036162
Can't access desktop, windows won't load so pc won't shut down
Hold th epower button down on your tower for about 5-10 seconds and it should shut off. Then you can turn it back on. If that doesnt shut it down you can always pull the power cord.
Apr 09, 2009 | E-Machines T3958 (827103050974) PC Desktop
Compaq Presario CQ50 Labtop, makes awful constant beeps
If you shut it down when WinFlash was running, then bad news - BIOS corrupted. This means faulty motherboard. Solution - replace motherboard.
Mar 11, 2009 | Acer TravelMate 2480 Notebook
PC does not respond to mouse or keyboard
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 05, 2009 | Computers & Internet
Dell Inspiron 1525 Laptop Jet Black (15.4" Wide Screen with true life, built-in Webcam, Intel Pentiu... PC Notebook Logo
Alun Cox
