SOURCE: My craftsman zts 7500 will not start.
The problem may be one of the safety switches. Make sure the blades are not engaged. The clutch pedal needs to be pushed all the way down, and there is another one that needs weight on the seat. Look around those areas for disconnected wires. Some even need to be in neutral. Lots of safety features.
The first thing to check is the fuse,it should be located underneath the battery.
SOURCE: Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
SOURCE: craftsman zt 7000 zero turn riding mower will crank but won't start and the starter get really hot
sounds like a safety switch problem. but maybe you can help me i have the same model do you have a lot of jerking when you start off of turn with yours?
