Question about Nintendo DS Lite Console
What is my solution for this problem I do not have an lcd display on either upper or lower screens. the screens light up but are both blank
  • 275 Answers
When did it first happen? You shoud try with a friend's battery and charger to see if you get anything different. If you already tryied that and tried taking the battery out and back in then pretty much there is nothing else to do, than get in contact with Nintendo to maybe consider a warranty exchage, or for repairs if warranty is expired.
Posted on Mar 09, 2009
Machine not working, there is no display on front panel
Several things you can try here. If the stops switch is stuck it will cause the display to be blank. There also may be a loose connection to the upper or lower board. You can remove the front cover and check the connections to the lower board. The upper display connection will look like a cat 5 cable. Unplug it and plug it back in. That same cable runs up and plugs into the upper board. Check that connection as well. If those don't work then it may be the lower PCA.
Jan 17, 2014 | Precor 932i Treadmill
When your screens blink.. What to do!
A lot of people have had the dreadful blinking of the screens. Whether it's only 1 screen blinking (upper or lower) , or both screens blinking..
I have a tip to help you diagnose the problem so you don't have to waste time trying to find out what's wrong with it, or waste money.
  • There is something wrong with your lower LCD and/or the connector on the board where the lower lcd connects to.
  • Open up your Nintendo DS lite system and clean the board with rubbing alcohol. Be sure to dry the board from excess liquid before re-assembling it. Use a FIRM brush. An regular toothbrush would not work as the bristles are not firm enough.
  • There is something wrong with your upper LCD and/or the connector on the board where the upper lcd connects to.
  • Follow the Potential Solution to #1
  • 99.9% of the time, if both screens blink, your light is red. Which indicates your battery is low. Change the battery. If your system isn't charing your batteries correctly and/or you're losing battery power unusually quick, replace the charger.
  • If that does not work, send your system in for repair, as the charging port needs to be cleaned.
on Dec 31, 2009 | Nintendo DS Lite Console
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
Whats the difference between Backlight inverter and LCD??
Liquid Crystal Display commonly known as LCD is an
electronically modulated optical device made up of any number of pixels filled with crystal.. The one you called the screen.. facing you when you are in front of the lcd monitor
It needs light source for this to have display... the light source whose responsible for the image to be displayed is the backlight inverter.. Its in the form of a cold cathode lights...frequently located at the upper and lower back edge of the LCD screen..
Hope i clear things out for you...
Much appreciated if you rate this help..thanks..
LCDs therefore need a light source and are classified as "passive" displays
LCDs are more energy efficient, and offer safer disposal, than CRTs. Its low electrical power consumption enables it to be used in battery-powered electronic equipment. It is an electronically-modulated optical device made up of any number of pixels filled with liquid crystals and arrayed in front of a light source (backlight) or reflector to produce images in color or monochrome. The earliest discovery leading to the development of LCD technology, the discovery of liquid crystals, dates from 1888.[1] By 2008, worldwide sales of televisions with LCD screens had surpassed the sale of CRT units.
May 23, 2010 | IBM ThinkPad T20 2647 Notebook
Lower half blank
1 (the lower one) of the 2 backlights is broken and needs replacing. If your warranty has expired it's quite expensive to get it replaced and you would be better of buying a new one.
Aug 24, 2009 | HP vs19 19" LCD Monitor
My phones display lights are not working.
Friend, it is in the keypad/light interface be sure it is firmly a little of that connection to restore the lights.
Jul 11, 2009 | Sony Ericsson Walkman W810i Cellular Phone
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Display malfunction (split image)
That means that your lcd is starting to go out. Call the repairs dept and see if they will fix it for ya. 800-706-2534 and option 2.
Nov 25, 2007 | Casio Exilim EX-V7 Digital Camera
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
