Question about Frigidaire FRS26R4A Side by Side Refrigerator
My Frigidaire #LSR7333PQ has had two compressor failures in 3 yrs
Frigidaire Model #LSR7333PQ4 has had two compressor failures in 3 years. Is there a "lemon law" for refrigerators? If not, what are my options?
  • midaws Mar 10, 2009
    For jumptrout: the technician doesn't have a clue. Midaws
  • steve
    steve May 11, 2010
    What did the technician say caused the failure?
  • Frigidaire Master
  • 3,361 Answers
Compressors fail due to:
bad capacitors.
bad start relay.
low voltage.
refrigerant leaks.
refrigerant restrictions.
bad fan motor.
to name a few problems.
You should be under a 5 year seealed system prts and labor warranty.
Call him back out.
Posted on Mar 10, 2009
Have upright Frigidaire freezer, about 2 yrs old, that quit running. Local repair guy replaced part with "3 n/1 Start" solid state relay overload capacitor combination. Worked great for 2 weeks then...
Good day,
That's a no-no. Your compressor carries a 5 year warranty from the factory. However, if anything is altered on it the warranty is voided. You've got an issue with this guy.
Jun 04, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Compressor wont come on
Check thermostat. Compressor relay. Compressor capacitor.
May 27, 2010 | Frigidaire FAA068P7A Air Conditioner
Frigidaire, chest freezer only 2 or 3 yrs old, was...
See if you have 120 volts at the compressor if you do do you hear any clicking sound at compressor if not replace compressor Start Relay/Overload if you hear clicking sound the compressor may be bad or Start Relay/Overload the only way to know is to replace the compressor Start Relay/Overload. If you do not have 120 volts at the compressor jump out the thermostat you should have 120 volts at the compressor now if not you may have a defrost timer Prob. if this is shelf defrost unit check timer turn knob to see if it starts.
May 19, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Have a 3 year old Wall oven and the racks don't fit properly anymore.Racks have either shrunk or the oven has gotten wider.
I have the CFES365EB2 Frigidaire slide-in model stove (3 yrs old) and I have the same problem. Did u get any answer ?
Dec 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
My gas dryer (3 yrs old today) wont turn. It just
O turned the drum by hand and it started running
Nov 04, 2009 | Frigidaire Dryers
My Frigidaire side/side has had two compressor failures in 3 yrs
Good question. TO give you an idea Id have to know what kind of failures they were.
1 Grounded, shorted, or open windings indicate an electrical problem. This could be caused by external components or power fluctuations. Or a manufacturer defect in the motor.
2 Stuck or not pumping indicate mechanical problems with what could be the compressor its self (again a manufacturer defect) or non defrosting trouble or contaminated refrigerant oil residue from the first compressor.
To me replacing the drier on any compressor and on most all refrigerant related problems is a requirement. This helps eliminate the contamination in most cases. If you purchased a compressor the drier should also be replaced on domestic refrigerators its usually a copper colored piece 4" to 8" long about 1" dia and same size tubes on both ends close to the 1" area. If your not getting this part replaced each time I feel like your not getting quality work done with comon refrigeration practices. And could lead to such a problem.
Back about 15 years ago one of the big appliance manufacturers were making their sealed compressor parts from composite materials that would not hold up in all environments of use. Compressor failures were rampant. I cant say this is the reason but I can say it cant be either.
Mar 09, 2009 | Frigidaire FRS26R4A Side by Side...
I bought a Frigidare refrigerator today. Warranty needed?
its really just up to you. I am a service tech in grants pass oregon and i know compressors dont last anymore. Its because in the last 10 years they have switched from r12 freon to 134a. 134a has higher head pressures which make the compressor go out. If the compressor warranty isnt too much money i would do that warranty. You dont really need the others.
Jan 29, 2009 | Frigidaire Refrigerators
Frigidaire freezer, only 2 bottom slelfs freeze
If your freezer is six years old the compressor warranty is also over. Sounds as though the system has lost its refrigerant charge. A refrigerant leak in these smaller units is difficult to locate and somewhat expensive to repair. Your choice.
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire side by side
there could be a partial restriction in the capiliary line causing higher that normal high side pressure in the system when the compressor is running
have the tech to replace the suction line along with the compressor let them know that this is the third one gone bad
Apr 26, 2008 | Frigidaire FRS26R4A Side by Side...
Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Dec 06, 2007 | Maytag MFI2568AE Side by Side French Door...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
185 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
