Question about Brother MFC-7220 All-In-One Laser Printer
I would like to scan several pages and have it save as one document. Currently each page is a separate document
  • Mike Mertel Feb 16, 2013
    The Solution Worked. Thanks!!!!
    Guru:
  • 832 Answers
Thanks for using fixya!!!
Just check the setting and instead of using JPEG select PDF file, to save your scanned documents.
Regards! if you need anything more, let me know.
Posted on Mar 09, 2009
After scanning several pages, I don't know how to save it as one file.
After you scan the first page, click on add another page or add more, or ahatever your particular program asks for to add another page. When you save as, the pages will all be in one document. If you scan each page, individually as a separate document, they will be just that, separate documents.
Jan 17, 2013 | Fujitsu fi-6130z - Document scanner -...
Every time I scan a multiple-page document into a PDF file using my HP LaserJet M1319fMFP, in creates a separate file -- or document -- for each page, rather than simply scanning all the pages into a...
There is no easy way of doing this.
What you can do is scan each page as an image file, then use an OCR program to convert each page into a text file and save them. Then open a fresh/new Word document, then open each text file page and copy and paste each text file page into this Word document.
After you have copied all the pages into this Word document, then spell check it, edit and format the text then save the document. You can then create a PDF file from this Word document if you need to.
Nov 28, 2009 | HP Pavilion dv6000z Notebook
When scanning a document, such document stays with the previous document scanned and wont save as a different file. How can I separate what I'm scanning from what I scanned previously on my computer? How...
If you had selected 'multipage' option, the scanner will convert all pages into a single page. Switch off (uncheck) multipage option and you will get individual page outputs. Check in the software if your clicked unnecessary button for saving in the last file. Try 'Default' button if available and try again.
Oct 16, 2009 | Bell & Howell B we Bell + Howell Truper...
Can't save multiple page scan to multiple page pdf document
that should be because you scanned the pages separately, did you notice if the PDF document converted was the very last page of the 13paged document which you wanted to make a document from? if that's right, then you just only converted the last scanned page into PDF, to stick all the pages together, i recoment you treating them as images and using word to stick them all together with the "insert>image> from archive" adjusting the size of the image at 1 page and with each 13 pages do the same until you have a full document of 13 images in 13 pages then you can convert it into PDF
Sep 14, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC420cn Document Scanning
Yes, you save it to a pdf file. Configure scan to file to save as pdf, and it will create a single file
Apr 30, 2009 | Brother MFC 420CN All-In-One InkJet...
Scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
Jan 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Scanning several pages and saving as one document
Try this....
Scan your multiple pages to an image file, like .jpg, I know it's tedious, name them (optional) by page number, put them into an empty folder.
When you're done with all the scanning, open the folder, select all of them, open with: Preview.
Now, you should see one page, with a side bar containing all of the pages. (If they're not in order, you can drag and drop within the sidebar to reorder.) Select all of those (Or Command A)
Command P (Or Print)
In this window, you should see page one, and below that, make sure it says "Page 1 of XX"...this way you know you got 'em all, and it's your final opportunity to page through them all by clicking on the little arrows to make sure they're in the right order.
Click the PDF button
Save as PDF...
See if that helps
Jan 15, 2009 | Brother MFC 420CN All-In-One InkJet...
Single scan printers can be difficult in this manner.\
Consider using the OCR (optical character recognition) software that came with your scanner.
Basically the part of the software that asks you what you are scanning (picture, document, newspaper) and make sure to select document. This will enable the character recognition which will convert the scanned picture into a document that you can configure to go into Microsoft Word or Notepad or whatever. If you have multiple pages, it MIGHT give you the option to scan more than one page at a sitting. then again, it may not. In which case you might be kicking yourself for not purchasing the scanner with the auto feed attachment! Once you have made your scanned document in your word processor - READ THROUGH IT! may have converted characters incorrectly - like an "S" may be now a "$" it happens - and it will happen. When done, attach complete document to email and BOOM done.
Either this or use a fax machine :)
hope i helped!
Ryan
May 31, 2008 | HP PhotoSmart C4280 Laser Printer
Scanning documents
Has the machine got a doc feeder if so select twain scanning select doc feeder and the scan it will scan all pages in the feeder and then you should be able to save as one file.
Thanks J
Jan 24, 2008 | Sharp AL-1551 Laser Printer
Brother MFC-7220 All-In-One Laser Printer Logo
127 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
