Question about Lands Phones
Changing display time
How do I change the display time on my Strata DK 16? The instructions I have say to dial intercom 6 5 1, but when I do this, I just get a busy signal....can you help?
  • 43 Answers
651 is to set the date, 652 is for time. Here is a link with more info.
Click here
Posted on Mar 10, 2009
NEED TO RESET MY PHONE CLOCK , TIME CHANGE.
Depending on the type of Toshiba phone system, the programming steps may vary slightly but this should get you on the right track.
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redia
Nov 09, 2010 | Toshiba DKT-2020 Corded Phone
How can I reset the time?
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redial
Nov 08, 2010 | Toshiba DKT2020SD Phone
How do i change the time on this phone?
Nov 08, 2010 | Toshiba DKT-2020-SD telephone
Please download me instructions on how to change time in our Toshiba Phones at work with Model No. DKT2010-SD. Also I am requesting a Manual for the Toshiba DKT2010-SD phone system. Your tech support...
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redial As far as the system manual goes, I'll need to know the type of system you have. Toshiba DKT2010's work with a number fo different Toshiba systems. To find out, go to where the phone system is located and look at the top corner. It should have a number designation there such as DK 40i or DK280 etc.
Nov 08, 2010 | Toshiba DKT2010SD Phone
NEED TO CHANGE TIME ON THE PHONE...HELP
There a few different types of systems that work with that phone. I'm guessing that its either going to be a dk 40i or dk 280.
Leave the handset on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds – enter a leading 0 for any single digit entered, press Redial, press Speaker. This must be done at extension 10 – usually the receptionist phone. For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker.
Nov 06, 2009 | Toshiba DKT-2020-SD telephone
HOW TO ''INT'' THE ENTIRE OFFICE
This is a partial guess, because an EKT phone probably sits on a Strata. Try Intercom 60 for all internal, 68 for all internal/external if you have it, and 69 for external only. The missing numbers are 1-4 for zones.
If it happens to be a DK, try 3x instead of 6x.
Carl
Mar 23, 2009 | Toshiba EKT 6010 S Corded Phone
Set time and date toshiba dkt2010-s
DK Programming
From Reception phone only
--(time set)DK- intercom #652 HH mm SECs redial
--(date Change)- intercom #651 yy mm dd redial
CTX Programming
--(time set)ctx-intercom #652 HH MM SEcs #
--(date change)-intercom #651 YY MM DD #
Jan 10, 2009 | Toshiba DKT2010SD Phone
To set time and date on toshiba
What Toshiba system do you have?
CTX Programming
DK Programming
Toshiba strata dk 280
it may be setup to block outbound calling, remember also, you have to dial a 9 to get dial tone on a centrex line, so in this case if your phone system is setup to dial 9 as a line access code you will actually have to dial 99. hope that helps
May 13, 2008 | Toshiba Strata PT-390 Corded Phone
Need to set my time on my phone
I think this feature is dependent on your system - the phone display is in agreement with the entire network. Check to see what system your phone is on - ours is a Strata DK-280 - and then search Google to find a total solution to changing time.
Dec 07, 2007 | Toshiba DKT-2020 Corded Phone
Lands Phones Logo
98 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
