Question about Lands Phones
Line 2 will not work it shows that is in use. But I've checked all the phones and it is not in use.
  • 63 Answers
Reset phone system
Posted on Mar 09, 2009
I have two lines lit up that will not disconnect
when you press the line button it may say "in use" and the have a extension #. That will tell you which phone or port has seized it.
May 08, 2012 | Nortel T7316E 2-Line Corded Phone
I have a Lucent 18D in the office and all the lines are working except line 3 of one of the phones. All the other phones and lines in the office are working. I've made sure everything is plugged i
Sounds like the line 3 button on that set is programmed as something else. When you press feature 00 and the line 3 button what does the programming say on the screen?
Feb 22, 2012 | Lucent PARTNER18 Corded Phone
How do i program the panasonic kxt-7731 so when a call is coming in i can just lift the handset to answer instead of pushing the co line
You have to do 2 things: Make it ring and turn on Line Preference-Incoming Ringing line. The first is done from SYSTEM programming in programs 408/409/410 for DAY/NIGHT/LUNCH. The second is defaulted to Ringing so if the phone rings, it's supposed to work. If you've changed it, then from your idle phone you press PROGRAM and dial 22 STORE. (21 is no preference and 23 plus a number is a specific line).
Apr 26, 2011 | Panasonic KX-T7731 Corded Phone
Phone lines are flashing making a loud beeping noise. The screen is texting funny words. Phone is ringing with ambulance style ring before the normal tone
The phone doesn't like something it's sharing a line with.
First, check to see if the extension number on each phone is different. You may have two extension 11's.
Next, check that line 1 is line 1 one all of the phones, then line 2 is line 2 etc. If one phone has line line 1 showing up on line 2 then you may have wires crossed somewhere. Or if you pick up a line on phone one and line 2 goes red on one of the other phones you have wires crossed.
Last, check in the plugs to make sure the connections are straight. Sometimes when a phone plug is inserted the pins cross and short two lines together.
Mar 18, 2010 | Panasonic KX-T7730 Corded Phone
I have a 974, 945, and 955 phones in a 2-line office. I am getting a squeal on the intercom when I call just one phone. It works fine between other phones. It worked for 2 years and then the squeal showed...
Check the battery on all the phones then make sure they are all programmed with different extension numbers. If the battery has been dead and you have had a power outage then it may have reset the phone to factory default extension 11.
Dec 03, 2009 | AT&T ATT-974 Corded Phone
Line buttons showing wrong phone lines
When a phone has only 2 lines, it's not programmed. By default, a Nortel system has 2 lines and that's all. Go into system programming and assign the number of lines and intercoms to a phone. After that, you can copy the buttons from a working phone to the new phone and you're done.
Jun 22, 2009 | NorStar Meridian M7310 Phone
Second line not working
The phone will show that "line in use" message when it's not connected correctly.
If your two phone lines come in to one jack, make sure you are using a 4-wire line cord connected to the "line 1 and line 2" jack on the phone. You may be using a 2-wire cord so the second line isn't reaching the phone.
If the two lines are on separate jacks you need to connect line 2 to the separate "line 2" jack.
If you know for a fact that both lines are properly connected to the phone and it still doesn't see the second line, then it's time for a new phone.
Dec 10, 2008 | AT&T E2562 Cordless Phone
Connect my phone adapter
You need to register/subscribe to a VOIP provider first like Vonage and the likes. Then you need to register through your VOIP provider the phone ports of your router. ISP is different from VOIP.
Oct 24, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Caller ID still not right
I have the same problem. By chance are you using Verizon FIOS? One line is VOIP and shows CallerID and the other does not.
Feb 08, 2008 | Panasonic KX-TG6702B Twin Cordless Phone
Lands Phones Logo
50 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
