Question about Hotpoint Dryers
Need to know how to replace the belt
Belt snapped on hotpoint diamond 9374 dryer - need help replacing
  • debbi_thomas Mar 12, 2009
    If there was a link to a solution from TheMobilian - | couldn't find it.
  • Hotpoint Master
  • 8,220 Answers
  • Dan Webster
    Dan Webster Mar 12, 2009
    Click on the above belt routings to get a pic of how your belt goes.
    Basically you open the dryer door and remove those screws holding down the top of the dryer. Then the top will raise up and you can get the front off. Once the front is off remove the tub and clean out the dryer. Use the link above to see belt routing details or copy this link:
    http://sites.google.com/site/sublimeappl...
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
Need to replace belt on vtd20g hotpoint tumble dryer
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
May 10, 2012 | Dryers
Hotpoint dryer dlb155obdlad will not turn. just replaced the belt.
first check to see if you can manually turn the drum ..then go to back of dryer in the center their is a cover plate...remove 2 screws to see the drum shaft ...remove the snap ring to remove the 2metal washers..and 1 fiber washer ..their should be a fiber sleave/bearing that slides onto the shaft that is in a metal bracket ...this is the rear support for the drum ..its prob.. out of bracket an grinding a big er hole ///or the front of the dryer drum slides are bad ..if you did the belt they are on top of the front panel of the dryer door they are plastic slides ..the inside of the drum has to be ontop of them to rotate ....let me know an good luck.../joe/
Aug 30, 2010 | Hotpoint NLL113EYWO Electric Dryer
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
I have a Hotpoint Dryer and the belt snapped, we purchased a replacement belt but are having a hard time figuring out how to install the new belt. The instructions call this belt a drive shaft. Please...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt,felt seal, and drum.
Remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
The route of the belt will go around the motor pulley first, then it will go around the idler arm bracket with pulley, then around the drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 15, 2009 | Hotpoint Dryers
Drive belt has snapped
Watch this video:
Jul 11, 2009 | Dryers
Hotpoint condenser tumble dryer model tdc30p belt replacement
You will have to unplug the dryer and remove the front panel with the door, mark and remove the wires to the door switch, then there should be two screws on the inside which you will need to remove then tilt the panel out and lift to disengage the tabs connecting it to the main cabinet. Then you should be able to remove the old belt, carefully lift the drum and slide the new belt under it. Then this is where you will need to be a contortionist and take care as there are many sharp edges under there. Locate the motor and tensioner pulley, place the belt around the tensioner and while pushing back against the spring on the tensioner hook the belt to the motor pulley, then move belt on drum so it is aligned with lower pulleys. Turn the drum by hand a couple of times to make sure everything works.
Apr 04, 2009 | Hotpoint Dryers
Hi i am trying to replace the large drive belt on hotpoint 17351 s/no 49440026 please can you show a route diagram thanks gwyn
Go to repairclinic.com and click on the "Repair Help" heading. On the following page is a link for "Dryer Belt Diagrams". Hotpoint will either be drawing M, D, or L. This depends upon the year your dryer was manufactured. I hope this helps you. Let me know if you need further assistance.
Aug 20, 2008 | Hotpoint Dryers
Dryers Logo
116 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
