Question about Motorola T5410 (14 Channels) 2-Way Radio
How is the battery compartment opened to replace the battery
  • Motorola Master
  • 1,654 Answers
1. With back of radio facing you, lift Battery
Latch up to release the Battery Cover.
2. Lift cover off.
Posted on Mar 10, 2009
I need to replace the battery in a Remington women's razor model wdf 1600
  • Open battery compartment
  • Note correct polarity and remove
  • Install new battery
  • Close battery compartment
  • Test operation
If the razor does not work, the replacement battery may be defective
Jul 12, 2016 | Remington Health & Beauty
How do I fix a jammed battery compartment in a kidde i12060 smoke detector?
You could try to pry the door loose with a small screwdriver. To be safe, make sure the primary 110V power is turned off before trying to loosen the compartment door.
This is an inexpensive unit, less than $10, and is easily replaced if you can't get the door open.
If you do decide to replace it, you may want to look into a combination unit which monitors smoke and carbon monoxide if you don't have a carbon monoxide detector already in your home.
Aug 26, 2015 | Kidde i12060 Hardwire w/ Front Load...
Spray WD-40 around the compartment door and try to let it trickle inside the compartment. That should break the acid corrosion buildup that holds the door from opening.
Oct 19, 2013 | Nikon F601 35mm SLR Camera
Where has the replacement battery CR1620 must be placed?
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Jul 20, 2012 | Polaroid Battery Grip for Canon EOS-7D...
Wont turn on
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you. You are having problems because you calculator won't turn on. I think you should try changing the batteries. Did you know that your calculator has two batteries powering it? Not only are the 4 AAA batteries powering it, but there is also a CR 3V Lithium Back Up battery powering it as well. First, try changing the 4 AAA batteries. If that still does not power your calculator properly, you will need to replace the lithium back up battery. You can find this at a department store or store that carries electronics. To do this, open your regular battery compartment. Above the AAA batteries is a compartment that says "BACK UP BATTERY CR1616 OR CR1620" with a picture of it. Use a small crosshead screwdriver to open the compartment. Take the old battery out and replace it with the new one. Rescrew the lithium battery compartment back on and close the AAA battery compartment. Turn on your calculator and see if that works. I hope this solution solves this.
Sep 27, 2011 | Texas Instruments TI-83 Plus Calculator
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
How do you change the battery on an Intermatic EJ500C timer?
Following link has photo of the battery carriage
Open door on EJ500.
Below button is battery compartment.
Use small tool to open compartment.
Befor pulling out batteries, notice direction that batteries sit.
Look at markings on battery.
Replace with same battery.
Jan 12, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
Just replaced batteries camera is brand new and wont turn on
Remove the backup battery. You will see a rectangular insert inside cover of battery compartment, closest to the hinges, pull out using fingernail. Close battery compartment with batteries inserted, turn on. Turn off open battery compartment replace backup battery. Reset date and time.
Jul 18, 2010 | Canon PowerShot A490 Digital Camera
Opening battery compartment on Midland LXT80 2-way radios
First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
Jul 07, 2010 | Midland LXT80 Two Way Radio
Need to replace internal clock battery
This may have been solved by now however...
REMOVE MAIN BATTERY... Before Opening any compartments!
The CMOS battery is located in the modem compartment.
Place the unit upside cown with the rear connectors facing towards you. It is the compartment on the right rear corner (i-screw to remove). It may be difficult ro open due to the modem labe sticking to the cover. Use care when attempting to pry door open.
Battery is CR1220 0.5in Diameter (Dime Size) (40mAh Rated).
Feb 22, 2010 | IBM ThinkPad 390X 2626 Notebook
Motorola T5410 (14 Channels) 2-Way Radio Logo
107 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
