Question about Kyocera Mita FS-C5020N Led Printer
Where it should be white it is printing out yellow. I have full toner cartridges.
    Genius:
  • 2,120 Answers
Open the left side door and push all of the colored units back in.
Posted on Mar 10, 2009
Have a bizhub c550 printer and when printing a plain white document i get a yellow background, What could be the problem?
Sir/Mam, have you replaced the yellow image unit ? Not the yellow toner cartridge. There two seperate units. Also there are on each image unit blue/white nubs that you can pull out and push back in to clean interal image unit parts do that you do not have to pull the image units out just ensure that when done cleaning they are pushed all the way back in. Once the image units are not toner cartridge and there are four of them located below each toner cartridge .
Jan 08, 2015 | Konica Minolta Bizhub C550
B&W Printing w/o Yellow Toner
yes, on most printers. just have to set preference to black and white in printer control panel
Jul 22, 2013 | Dell 1320c Laser Printer
White lines when printing
Usualy white lines are a signal for you that is time to replace a toner cartirdge.
Your machine may inform you that you need to replace a toner cartridge, but sometimes the toner levels are low and the machine doesn't indicate that.
Another thing that you may try is to clean all toner cartridges using each corona wire.
If you need to replace your toner cartridge check this easy and helpful way to replace toner cartridge.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
I have a C252. The last 2 days is asks for Cyan toner although its got a full toner cartridge in. It now also starts to ask for yellow and the same apply. The yellow cartridge is still full. When switching...
Your description first looks like you refilled the toner cartridges, if so you need to replace the toner chips. Secondly, for running straight to waste tank, it could be due to the run out chips or the toner quality isn't the best. So get the toner chips first, and if the toner still runs to waste ensure you get a genuine Konica Minolta toner. Because you could run into more problems with a bad toner.
Apr 29, 2017 | Konica Minolta Office Equipment & Supplies
Hello. I am getting a message that my yellow toner cartridge is empty and the printer (Konica Minolta 2300W)refuses to print out anything, even though I got it into the B/W mode. The complete message...
It won't print anything if one cartridge is empty, even black when the colour is empty. Are you using new or refilled cartridges? The cartridge has a chip on top that counts your number of prints, so it could feel full, but has reached it's end counter. Try another cartridge. That should solve your problem
Aug 06, 2010 | Konica Minolta magicolor 5430 DL Laser...
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
I just replaced the yellow and cyan cartridges on my Lexmark c522 color printer and now a light yellow color prints out on every page I print, even standard black and white. What should I do. Thanks
Remove the yellow cartridge. Pull back the shutter that covers the drum. Check to see if its covered with yellow toner. It should be fairly clean. You can pull another one and do the same to compare. If theres a lot of toner over it then the cartridge is bad.
Dec 19, 2009 | Lexmark C522n Laser Printer
Printing in grayscale
yes u can use it with black and white
Nov 01, 2008 | Dell 3010cn Laser Printer
Yellow toner will not print
If you let the yellow toner get to the point where the toner cartridge was totally empty, there is one thing you can try which may help. From the "menu", select "maintenance", then go to "clean developer" and choose the yellow. The machine will then churn for a few minutes. What happens is there is a tube that moves the toner from the toner cartridge down to the developer unit ( which is behind the imaging drum). If the toner was allowed to totally run out, there is an area of the tube which may have little or no toner in it. Each time you print, there is a spring auger within the tube that draws the toner to the developer. By running the "clean Developer" it turns the auger and re primes the tube.
If this does not fix the issue, and you have replaced the imaging unit, then the yellow developer is defective and would need to be replaced. This involves quite a bit of work and is not considered user replaceable.
Aug 20, 2008 | Dell 5110cn Laser Printer
Kyocera Mita FS-C5020N Led Printer Logo
110 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
