Question about Nakamichi Audio Players & Recorders
I HAVE A NAKAMICHI RX-303 CASSETTE DECK THAT I BOUGHT AT A THRIFT STORE. I BROUGHT IT HOME AND PUT A TAPE IN IT AND IT WOULDNT PLAY FF OR REWIND, SO I OPENED IT UP AND FOUND THAT THERE WAS A SMALL BELT MISSING. THE CAPSTAN BELT WAS FINE. I REPLACED THE 1 BELT AND TRIED IT AGAIN AND IT RAN REAL FAST IN PLAY.IS IT A MAJOR PROBLEM? WHAT CAN I DO TO RESOLVE IT? ANY HELP WOULD BE APPRECIATED. STEVE!
5 Suggested Answers
  • 4234 Answers
SOURCE: RX-303 NAKANICHI & TEAC-2000X REEL TO REEL
These decks need a complete overhaul. There are belts and "idlers" inside that are made from rubber that have dried out and slip. The Rx-303 needs a tire replacement. This tire only comes into play when in play mode. The FF and REW functions are powered only by a belt. Changing hte idler tire is a bit tricky in these units if you have not replaced one before. Given the value of these units, I'd recommend that you have a servicer in your area overhaul these. The parts expense should not exceed $15 for either deck. Check in the area for the labor costs. Both units are definately worth the repair cost.
Dan
Posted on Aug 08, 2008
  • 3 Answers
SOURCE: where can i get a clear plastic cassette door for
ebay
Posted on Sep 22, 2009
bbl242003
  • 1637 Answers
SOURCE: I have a Nakamichi RX 303 cassette deck. I press
follow this same reset process for your deck
hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving.
Posted on Jan 27, 2011
emissionwiz
  • 77499 Answers
SOURCE: I am looking for the cams that fit on the back of the control levers play, fast forward, record,reverse on a m9 tape deck.
Sorry we do not have parts here, also we have no way to look them up.
Posted on Jan 10, 2017
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Mar 19, 2010 | Audio Players & Recorders
Hi, My Pioneer CTF-7272 Cassette Deck has stopped playing. Rewind works fine, but FF and Play will run for about 5 seconds and then the tape just stops. Any info on this problem is greaty appreciated....
check the belt whether it is broken or loose. if so replace the belt.
I hope this will solve your issue.
Good luck
If my solution proves useful please rank it.
Regards
Arjun.
Mar 27, 2009 | Pioneer CT-W205R Single Dual Cassette Deck
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
Denon DRM 740 tape does not play
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
Apr 12, 2007 | Denon DRM-740 Single Dual Cassette Deck
206 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
