Question about Saniflo & Saniplus& Macerator Pump
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the Saniplus becomes really noisy, it makes a loud grinding noise likes its struggling. Is it to do with the amount of water going through the pump? And is there anything we can do??
  • nivek1 May 11, 2010
    How old is it?
  • 600 Answers
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Posted on Mar 18, 2010
Water is flowing back to shower tray macerator not switching on
Usually Saniflo requires 8" or 9" from top of p-trap to floor level, not from top of shower base to floor level. If the base is raised 8" then you will have enough room to fit a p-trap without cutting the concrete, if you had cut the floor to fit the p-trap then the base is not raised high enough to maintain the water pressure inside to engage the unit.
Mar 22, 2013 | Saniflo & Saniplus& Macerator Pump
We have a basement bathroom. The bath drains away very slowly, but everything else seems fine - toilet and sink draining/flushing fine. Can we use a usual unblocker (eg sodium hydorchloride) to unblock?
I worked on a lot of Saniflo products, they do not recommend using any products that have bleach or chlorine. Make sure the flapper inside the side inlet where the bath drains, is not obstructed.
Dec 03, 2012 | Saniflo & Saniplus& Macerator Pump
Saniplus has bath water going into it as well as toilet water.Why does it take at least two flushes before the bath water all goes?
The Saniplus works on a float switch which is a rubber membrane in the pressure chamber (where electrical components are) water pressure pushes up in the membrane and the unit kicks on and pumps the waste out. Once the pressure releases, the membrane goes back down and shuts off. If the membrane is warped or solids are build up at the bottom, it will not allow it to kick on and off as it should. You might want to inspect that membrane and have it cleaned or replaced.
Jan 17, 2012 | Saniflo 002/005/007 Saniplus Toilet with...
Bath takes about hour to empty toilet works ok flushes ok
go to lowes, walmart and get some drain-o prolly clogged by hair.
May 23, 2011 | Saniflo & Saniplus& Macerator Pump
Vent on top is blowing bubbles and toilet pan is filling up with effluent
If you have a Saniplus model then the vent connection is on the top right side of the pump casing if you are facing the toilet with pump sitting behind. The vent pipe needs to be minimum 1 1/2" and must be vented to the open air so air can flow in and out at all times. To the left side of the vent connection is the discharge pipe which should be a 3/4" or 1" discharge pipe. You can try disconnecting the vent pipe and run it with the vent pipe open, also you can disconnect the discharge pipe and put a bucket at the end of the discharge elbow and flush the toilet into the bucket, it will free flow into the bucket and there are no restrictions. That way you can tell if the problem is the pump or the installation set up.
Dec 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
It starts up before I flush!
is your saniplus connected to a shower or hand basin. if so - some water could be getting into the saniplus while you are on it and causing the unit to operate while you are "on the bowl". dripping taps / valves or a "leaky" toilet cistern are the most likely sources.
Dec 04, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
Helicopter starting :)
could be the thermal trip on the motor. Suggest you remove the lid and clean out any buildups inside. check for for a jam,around the blades like a tampon. Careful - they are very sharp!
Oct 01, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Our Saniplus pump runs for no apparent reason. Do I need a plumber, an electrician or a new unit?
if the pump operates then the pump is ok. if the pump switches on for "no reason", this indicates that the saniflo unit is filling slowly with water. as you have a saniplus, then you probably have a handbasin and bath / shower connected to it. If the taps / valves drip, or the wc cistern "leaks" into the bowl then these could be the sources.
Sep 14, 2009 | Saniflo & Saniplus& Macerator Pump
My saniflow saniplus has stopped pumping water i think- the toilet and bath has filled up with waste water. i have taken the top off the saniflo and blades are working fine but they keep going because the...
We had that problem but the unit was built in and I could not get at it, the outlet pipe sounds like it is blocked, I cleared mine by connecting a pipe from the cold tap to the outlet pipe and flushing.
May 11, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo & Saniplus& Macerator Pump  Logo
1,215 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
