Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer does not get hot
Mde 5500ayw, serial# 36491387zok, style# y7875634
how do you get to the heating element on the dryer
  • Anonymous Mar 24, 2009
    Dryer doesnt heat
    Guru:
  • 462 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}On my Maytag dryer it is accessible from the front of the dryer. 2 to 4 screws keep the front in place remove them and pull the front out and up from the bottom it may be hinged at the top. Now you should be able to see the element heater box.
If you feel confident here are the main things to do onchecking for no heat Electric Heating Dyrer
1 Check for 220 Volt at the heater entrance to the heaterbox (accessible from picking up the top on most dryer models).
If you have 220vthere the heater element is out.
2 If you don't have 220v on the terminals of the heater theproblem is in the controls.
The fuse link, thetimer contacts, the centrifugal switch on the motor, and the heater safetythermostat and operating thermostat(s), are all suspect and have to beeliminated 1 by 1.
Hope this helps.
With any luck all you need is a new element. Clean the ductout while replacing the heater if so because the main thing that causes heaterelement burn out is low air flow. A kinked Dryer vent hose, lint, and pluggedup fan circulator on the motor, or if yours has little holes in the insidecabinet where the air is taken to be heated and recirculated, these can getclogged with lint also and cause a problem are the 4 main causes of low airflow..
Hope this helps and please rate me accordingly Thank you andgood luck.
Posted on Mar 13, 2009
Heat cuts out shortly after dryer starts. Have taken apart several times. First replaced thermal cut off (tested bad) and thermostat. Element ok. Good airflow. Dryer seems to heat up very quickly and very...
Sure can!
Most Kenmore style dryers have a heating element that has a long wire coil inside it, (often there are two wires or elements inside one housing). Regardless, if you have carefully checked the air exhaust, and you find it is "perfect" ( means no back-up heat from a plugged or impeded air flow) and you have determined the air flow inside the machine is like new, ( no back up there either), then what has possible happened is the wire heating element has wiggled loose and is touching itself, thereby shorting out and making super heat.
The wire coils are usually held loosely in place with white ceramic rings, to keep them from touching the metal housing. If you carefully remove the heating element "box or "tube" and look inside , you may be able to see the problem. Testing it with an ohm meter will not work, it will simply test OK. The element is made to heat at a certain temperature according to it's length, if it touches itself, the elecrttricity will take the shortest route and may make your element glow white hot in one spot. Be blessed.
Sep 02, 2013 | Kenmore Series 70 80 90 PN281798 Dryer...
Dryer won't heat maytag neptune mde 5500 ayw
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer kicks circuit breaker
Hello, Mark I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Jul 03, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do I put a heating element in a dryer?
there are a few differant styles, give me your model number and i will see which one you have.
why do you think it needs an element? if its not getting hot you may have a cheaper and quicker repair than an element
Dec 10, 2009 | Whirlpool LER4634J Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
My Neptune mde 9700 dryer heats inconsistently. more times than not it take forever to dry a load nomatter what the size
you have either a thermistor at fault of the heating element isnt operating properly
Aug 21, 2009 | Maytag Dryers
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Jun 14, 2009 | Kenmore 63942 Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
356 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
