Question about Lands Phones
DCP Attendent 302C putting calls on hold everytime
I have one DCR Attendent 302C. Since yesterday, it is putting callers on hold. We pick the phone receiver on the 302C but call still remains on hold. It continues to beep and blink red light. Is ther a way to put it back to state where it would not put calls on hold (unless operator is busy).
  • 1 more comment
  • sawangahra Mar 09, 2009
    I do not have a manual. I am new to the system
    localwonder
    Rank: Wiz Rating: 84%, 165 votes
    I suggest a proper hard reset by unplugging this unit for 5 min. this should fix the software scramble.
    I unplugged it last night but it did not reset itself. I do get few calls (sometimes) to the phone. It is not putting all the calls on hold :-(
  • sawangahra Mar 10, 2009
    Shadow1989
    Rank: Wiz
    Rating: 83%, 61 votes
    This should tell you everything you need to know.http://support.avaya.com/edoc/docs/def7_...
    I plugged off the 302C and then switched off the Night Mode. It still does not take the calls from outside. the Position Available light is on. There is a "ALARM FAILED" light that is on. When I press the button next to "Alarm Failed" button, it shows number 748 on the screen. What is this and it seems alarm failed may have caused phone not to take calls.
  • 19,396 Answers
You need to use the phone software to Restore Factory Defaults.
Visit the Download Center to download the software.
Posted on Mar 16, 2009
  • 10,515 Answers
If we talk about error 748, an attempt was made to exceed the number of users making a connection.
Possible reason- technical issue
Solution- Reset the system. Remove all connections. keep it off for few minutes. Again make all connections.
if not resolved, call technician.
Thanks for using Fixya.
Posted on Mar 10, 2009
  • 583 Answers
You can place callers on hold to answer other calls or to find information for the caller. You can have a call on hold at each of the 6 call appearances. To place a call on hold, perform the following: 1. While on an active call, press the HOLD button. n The On Hold lamp at the call appearance button goes on. n The call appearance lamp goes off. n The display goes blank. n The Position Available lamp goes on. n The console returns to the normal operating mode. To return to a held call, perform the following: 1. Press the call appearance button where the call is held. n The On Hold lamp at the call appearance button goes off. n The call appearance lamp goes on. n The Position Available lamp goes off. n The person who was on hold is reconnected to the console. n The person’s name (if available) and extension are displayed. 2. To end the call, press the RELEASE button. n You are disconnected from the call. n The call appearance lamp goes off. n The display goes blank. n The Position Available lamp goes on. n The console returns to the normal operating mode. NOTE: When the On Hold lamp flashes, it indicates that the hold time has expired. When this happens, the console also beeps to indicate that a call needs attention. Press the call appearance button and answer the call.
Posted on Mar 09, 2009
    Brigadier General:
  • 5,158 Answers
When you unplug it you need to unplug the adaptor as well as the phone line.... it gets some power from the phone line as well
    Sergeant:
  • 300 Answers
The following is a typical scenario for answering overflow attendant console calls from a backup telephone: 1. The Calls Waiting In Queue threshold is reached. n The backup telephones beep and will beep every 10 seconds until the calls in queue go below the threshold or you shut the ringer off by pressing the RINGER CUTOFF button. n The Queue Calls lamp starts flashing. n If calls remain in the queue for 15 seconds, the Queue Time lamp starts flashing. 2. Press either the QUEUE CALLS or QUEUE TIME button. n The display shows how long the calls have been waiting in queue and how may calls are in queue:3. To answer the first call in queue, dial the Trunk Answer Any Station feature access code _____ or press the automatic dialing button administered with that feature access code. 4. When finished with the call, hang up. In addition to answering overflow calls, you can use the backup telephones in a hospitality environment to handle guest requests such as wakeup calls. To do this, the following feature buttons must be administered on the backup telephone(s): n Automatic Wakeup n Check-In n Check-Out n Do Not Disturb Extension n Night Service (a NIGHT button can be assigned on only one backup telephone) n Busy indicators for the attendant console and the other backup telephones. Busy Verification The Busy Verification feature allows attendants and backup telephone users to make test calls to see if a trunk is actually busy or out of service. To use the Busy Verification feature, perform the following: 1. At the attendant console or a backup telephone, press the BUSY VERIFY button. 2. Dial the trunk access code followed by a specific trunk number (such as, 01, 02, and so on). One of the following occurs: n If the trunk is busy with an active call, you are bridged onto the active call. All parties on the active call receive a warning tone (2-second burst of 440 Hz tone) to let them know that you are bridging onto the call. A half-second burst of warning tone repeats every 15 seconds, as long as you remain on the call. n If the trunk is out of service, the busy verification is denied. You will hear reorder tone. n If the trunk is idle and it is an outgoing trunk, you will hear dial tone. You can make a call on that trunk to verify that it is in working order. If the trunk is an incoming trunk, you hear a confirmation tone which indicates that the trunk is available for use. 3. Press the RELEASE button to end the call from the attendant console, or go on-hook from a backup telephone. To activate Call Forwarding - All Calls, or Call Forwarding - Busy/Don’t Answer for an extension, perform the following: 1. Press the START button or an idle call appearance button. n You hear a dial tone. n The call appearance lamp goes on. n The Position Available lamp goes off. 2. Dial the Call Forwarding - All Calls activation feature access code _____ or the Call Forwarding - Busy/Don’t Answer activation feature access code _____. n You hear a dial tone. 3. Dial the extension of the user who wants his or her calls forwarded. n You hear a dial tone. 4. Dial the number to which you want to forward calls (the forwarded-to number). Listen for call-progress tones: n Confirmation tone — Call Forwarding is activated. n Intercept tone — The feature cannot be activated because of restrictions assigned to the forwarding number or the forwarded-to number. 5. Press the RELEASE button. n The call appearance lamp goes off. n The display goes blank. n The Position Available lamp goes on. n The Call Forwarding feature is now activated. n The console returns to the normal operating mode. To cancel the Call Forwarding - All Calls, or Call Forwarding - Busy/Don’t Answer feature for an extension: 1. Press the START button or an idle call appearance button. n You hear a dial tone. n The call appearance lamp goes on. n The Position Available lamp goes off. 2. Dial the Call Forwarding deactivation feature access code _____. n You hear a dial tone. 3. Dial the extension for which the feature is being deactivated (the forwarding extension). n You hear a confirmation tone. This indicates that the feature is deactivated. n The call appearance lamp goes off. n The display goes blank. n The Position Available lamp goes on. n The console returns to the normal operating mode.
  • 408 Answers
http://support.avaya.com/edoc/docs/def7_1/d71qref3.pdf
  • 6,784 Answers
    Sergeant:
  • 320 Answers
Yes try to reset by entering all its settings again.as new./
Old Norstar phone-one line seemingly tied to one extension
You most likely need to call in your tech who looks after the programming there.
Needle in haystack, sticky button, bad programming, glitch in system, answer dn etc.
Dec 10, 2012 | NorStar M7310 Corded Phone
How do i transfer a call with my norte t7316e
There are 3 Flexible Feature buttons under the horizontal display. When you are on a call, the display will show "Transfer" over the last button. Press that button, which will automatically put the caller on hold, pick up an intercom and prompt you to enter the extension to transfer the caller to. Enter the ext. number and tell your employee who is on the call, and heng up - the caller will be connected automatically. Or, after dialing the ext. to transfer the caller to, just hang up and the call will ring through. Good Luck!
May 05, 2010 | Nortel T7316E 2-Line Corded Phone
How do i put a caller on hold
Tha particular phone does not have a HOLD button. If you are referring to picking up a call waiting call that "beeps" in while you are on your current call, that can be answered by depressing the FLASH/EXIT button.
Here is a link to the manual:
http://www.home-electronics.net/USER-GUIDES/29586_DOM_EN_CD_IB.pdf
Nov 20, 2009 | GE Lands Phones
How do I put second call on hold while finishing first conversat
FIRST U HAVE TO HOLD FIRST CALL. AND TAKE THE SECOND CALL.THEN HOLD SECOND CALL.FIRST CALL AUTOMATIC ACTIVATE.OK
IF HELPFUL THEN PLEASE RATE
Jul 10, 2009 | Uniden DXI8560-2 Twin - - Phone
HOW TO DO A CONFERENCE CALL
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
May 14, 2009 | NorStar M7324 Telephone
Call conferencing
May 11, 2009 | NorStar Meridian M7310 Phone
Unable to use conference button
Mar 11, 2009 | Nortel Meridian M7208 Corded Phone
I have a NorStar M7310 phone -I am on a conf call - how do I mute the line where the other parties cant here
Dec 04, 2008 | NorStar M7310 Corded Phone
Caller ID on Mitel Superset 4025
Try pressing the superkey button and then the button that is ringing
Sep 12, 2008 | Mitel Superset 4025 Corded Phone...
Lucent DCP Attendant Console 302C
For the 302c, you first hit either volume up or down on the upper right of the console, THEN you hit the SELECT button which is to the left of the 2 volume buttons. on the display you will see likely "Ringer volume" so hit SELECT AGAIN, then you will see "HEADSET VOLUME" then you can hit the volume up to adjust the headset volume.
This took me about 10 minutes to figure out, so don't feel bad.
Dec 05, 2007 | Lands Phones
Lands Phones Logo
172 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
