My A/C for a 1998 Pontiac Bonneville will not come out of the vents inside the car. My A/C had been pulled down and freon has been added, the compressor comes on. I have the same problem with the heat it will not come out of the vents inside the car.
  • dllb001 Mar 09, 2009
    1998 Pontiac Bonnville. My A/C will not blow out of the vents I have the same problem with the heat. I was told by a shop that the A/C unit is working fine and my blower is working fine, and the fuses have been checked.
    1998 Pontiac Bonneville. The A/C will not blow out of the vents inside the car the A/C has been chagred and the fuses are fine, the blower works fine I was told at a shop that the A/C itself is working fine. I also have the same problem with the heat.
  • 19,396 Answers
Either the heater control switch or the mode valve is faulty or the mode control valve is bad.
Check the link below for more details.
The air conditioning does not blow out the vents but through
Posted on Mar 16, 2009
    President:
  • 1,314 Answers
Try removing the blower motor and blow out any debris that may have been caught in the airway...leaves and other buildup over time will decrease or completely stop the airflow.
Posted on Mar 09, 2009
  • 583 Answers
Check all of your vacuum lines from the ac control panel and under your hood. You have lost vacuum somewhere witch controls your vents. There is one of them loose, disconnected or broken. Should be easy to trace. Good Luck!!
  • 6,784 Answers
Hi, replacing the blower motor will fix this issue. Just to be safe, check the fuse box to see if the fuse is blown before purchasing a new fan motor. i suspect a blower motor failure.
    Brigadier General:
  • 8,619 Answers
Hi!
Check for voltage at the blower motor on all settings. If no voltage, check the blower motor resistor or relay. If it has a resistor it will be right beside the blower motor, if it has a relay it will be the relay on the firewall under the hood. It will probably have a purple, orange,blue,and black wires.Please check any loose connection
Thanks for using FIxya
Rylee
  • 408 Answers
  • Shadow1989 Mar 09, 2009
    Actually, after re-reading your post, I answered assuming that you have heat or air coming out of defrost and floor.  Does your blower motor work?
  • 4,472 Answers
Nothing is coming out of the vents? Can you hear the blower motor working? or is it blowing? Does it sound like its blowing stronger when you turn it up? It is most likely either vacuum lines or the temperature selector itself.
Thanks,
Lee
  • Lee A.
    Lee A. Mar 09, 2009
    Once I have more information I can assist you further. Also please take a moment to accept and rate my solution accordingly.
    Thank you,
    Lee
    Brigadier General:
  • 5,158 Answers
The vent which is controlled by vacuum is not working.... listen for a vacuum leak under the dash... also you will see a small vacuum cannistor near the firewall in the engine compartment... give that a few taps to free it up tho it may need replacing
  • 64 Answers
Does the blower blow any air out of the vents? If not you may have a blown fuse, check your manual to see which fuse powers the blower, if not blown then you may need to replace the relay or the blower itself.
I need to know the location of the hvac heater blend door actuator on a 1998 pontiac bonneville se
Inside the dash ductiong about center of dash. You must remove the dash to get at it.
Apr 17, 2014 | Cars & Trucks
1998 bonneville heater air
sounds like either the door isn't opening all the way or some of the tubing has either come off or has holes.
Dec 31, 2013 | 1998 Pontiac Bonneville
98 bonneville , blower only blows cold air , replaced control head and thermostat, heater core is good , there is hot air at the blower motor
This is usually caused by a control door inside the housing for the heater. Sometimes pens or other obstacles go down the defroster vents and block the doors. Lay on the floorboard while someone controls the heat and vent controls. You should be able to see the arms controlling the vents and heat. You may have to remove the lower dash covers to gain access to see these controls. Also check to see if there are any engine vacuum leaks. The heater and vent controls are ran by vacuum sometimes.
Dec 29, 2010 | 1998 Pontiac Bonneville
How many cans of freon should i put in me 95 pontiac bonneville
None, unless you know how much is already in it. what are you high and low pressures? what is the ambient temp? what is the vent temp? Leave it to a pro. Fix the leak. then have it recharged with the correct amount.
Jun 04, 2010 | 1995 Pontiac Bonneville
Heater blows sometimes but not others
cheap resolution try adding anti-freeze.
costly solution may be a bad heater core.
Jan 18, 2009 | 1998 Pontiac Bonneville
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
