Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Have a colemen presidential II- when it is windy at all the pilot light blows out- have checked the vents and have no wind threw them. you can see the wind just howling threw the heater area where the pilot light is
    Guru:
  • 462 Answers
Remove the burner and gas valve from the furnace and use compressed air to blow the area under the pilot area ans all around it. The dust and stuff usually cause a condition called "Lazy Pilot" and the flame is probably not going in the designed directions. While you have it out Id replace the thermocouple with a new one reassemble and re-lite and note the difference. The flame should be mostly Blue and no yellow (or vary little at the top end of the flame only) Orange in the top area indicates a good burning flame and the closer to the base the bluer it gets.
While you have the burner out look inside and inspect the inner heat exchanger for cracks or rusted open holes there should be none. Turn on your fan while inspecting and see if you feel the steady blow of air from it inside the heat exchanger indicating a hole. Don't confuse the air that may come down the flue with the air from the blower though. A little breeze is expected from this.
This will take care of over 90% of the problems with the "Blow out" symptom.
If you still have problems you can try and "turn up the pilot". Usually a screw close to the pilot tubing is covering the adjustment screw. Put some soap bubbles around it so you can see if it leaks or not and turn the screw out for more flame (CCW) and in (CW) for less.
Hope this helps Please grade me accordingly and good luck.
Posted on Mar 11, 2009
Combustion switch error on windy days
check gas pressure and flame sensor
Jan 06, 2018 | Coleman Heating & Cooling
So much air blowing in the pilot on DV-35-2SG heater won't stay lit
Unfortunately if its wall vented the wind can hit it just right and pop off the pilot this happens on older models a lot check your vent if its too much of an aggravation you may have to relocate it
Jan 17, 2013 | Empire DV-35 Heater
Would high winds and rain cause pilot light on a rannai tankless water heater to go out?
Yes.
High winds can cause reversal of air flow down vent pipe causing pilot flame to blow out.
If situation happens frequently, then special roof cap has to be added.
Have plumber check natural draft up vent pipe.
Other things can cause same problem, for example if vent fan is located in same room as water heater, or house is tightly insulated, and vent fan is ON, then it will draw air down the water heater vent and blow out pilot.
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
Oct 29, 2012 | Water Heaters
Why does the pilot light blow out on the water
Your vent pipe needs a cap. You should be able to find one at your local building supply store; just tell them your problem, and they will find the right product and let you know how to best install it.
Oct 12, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Smell gas leaking out on windy days, pilot is still lit though
it sounds like the flue pipe out side may have something blocking it , it has a fresh air return on it and when the unit is blowing out it also pulls in the outside air, make sure ther is nothing in the way making the air circulate back in,
Mar 25, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Need replacement glass for pilot cover of Coleman Presidential II
the glass is there as a service tool to veiw pilot and flame or relite just get a peice of sheet metal and cover hole with it ,it will work short term or long term
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II mobile home furnace. When burner lights the blower cycles on and off instead of blowing constant through burner cycle.
Is this furnace standing pilot or electronic ignition. If standing pilot i would check furnace filter then the thermastat. To test themostat first turn power off to furnace. Take thermostat off wall and take wires labled R & W and connect them together. If you have electronic ignition I would start with cleaning the flame sensor with steel wool or wire brush.If you have and more questions i will be glad to help.
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II Heater won't come on
You should have 3 wires going to the gas valve - MV(mainvalve), PV(pilot valve) and MV/PV (or Common). Make sure all of these are properly wired and tight.
You also may have a dirty FLAME SENSOR on your pilot/ignitor assembly. You may need to remove the pilot tube and the pilot assembly to clean the sensor with sandpaper.
Be careful not to damage any parts while cleaning them. Be careful not to crossthread the gas line when re-installing it.
Jan 03, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
135 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
