Question about Brinkmann 805-2101 All-in-One Grill / Smoker
Just bought a used brickmann smoker
When I got the smoker home and cleaned up found spots that rusted through the cooking part any suggestions how to repair?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
My Bar B Chef grill grates are totally rusted. Are stainless steel grates better or should I stick with cast iron?
I prefer cast iron. Cast iron heats more evenly and retains temperature better. If they are falling apart from rust, junk them. If they just have surface rust and no holes, all you have to do is brush them with a steel brush at high heat. Wipe them off with a wet rag and then rub it with an onion to provide a teflon layer. if it is really heavy rust, spray oven cleaner on them and hose off. After use or for storage, clean them and then wipe them down with a cooking oil soaked rag. The oil will reduce rust build up.
Feb 28, 2015 | Grilling
I have faberware stainless steel knife set knives have rust spots. What & why??
How do remove rust spots from stainless steel Yahoo Answers
Yes, stainless will rust. The above link has helpful information on how to treat rust spots on stainless. The web site suggests using a mild acid, such as oxalic acid, which can be purchased at Home Depot or Lowes. Use a green scrub pad, as recommended. Hope this helps....
Apr 28, 2014 | Refrigerators
My oven hood has developed small rust colored spots on it. It is barely 5 yrs old and is stainless steel. I'm wondering what it is from and how to clean it without damaging it.
Your oven hood is "ferritic" stainless steel. Simply put it has iron in the alloy, and the appearing spots are rust. Use DeBruce Polish to remove the corrosion and "PACIFY" the surface. DeBruce Polish is non-toxic, odorless and non-abrasive. This multi - surface cleaner also works wonders on glass cook tops, chrome, polished granite, marble, fiberglass and more. A powder, simply use with water and terry towels. DeBruce Polish can be found @ debrucepolish.com
Sep 06, 2013 | Ovens
How do we fix a gas grill that doesn't cook evenly
Usually if you're have hot and cold spots, it's the burners that need to be removed and thoroughly cleaned. In addition, cleaning the venturi valves while the burners are out, is equally important. The Venturi valves are part of each burner. You will see them near the open end of the burner (looks like 2 slots cut into each side of the burner) where it fits over the burner orifice. While the burners are out, closely inspect each one for corrosion or rust thru. If you find severe corrosion or rust thru, the burner(s) should be replaced.
Hope this helped you troubleshoot and solve the problem. Happy Grilling!!
Jul 04, 2011 | Weber 3820301 Gas Grill
Rusted Grill Grate
and why do you want to replace it? just use bit of wirebrush, scarape off biggest bits, wipe rest with cooking oil and use as normal.
after cooking wipe clean (do not wash!!!) and use bit of cooking oil again to preserve it.
Jul 19, 2010 | Weber Q Grill
How to clean and maintain grills after cooking
When you say oil I assume you mean cooking oil. Cooking oil will do nothing to remove rust. If cast iron grate try to re season them. If steel grate use some S.O.S or a soap pad then spray with Pam. Hank
Jul 19, 2010 | Char-Griller Char Griller Pro Deluxe...
Cant find a teflon repair spray product
Teflon, if nmot applied properly to cooking utensils can be toxic, thus there are no home remedies for your problem.
May 15, 2010 | Grilling
My 30400040 is rusting to pieces and is only 3
the casing sould have a long warranty but the burners and the cook surfaces do not
you must keep them oiled with veggie oil after cleaning to prevent corrosion
i keep a pump bottle with oil for this reason
Jun 25, 2009 | Ducane 30400040 Stainless Steel Grill
Brinkmann 805-2101 All-in-One Grill / Smoker Logo
78 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
