Question about HP Pavilion dv9000z Notebook
Just had my dv 9000 lap top in for repair... mother board cpu fault... now that i have it back the lights on the bottom left ( for the power hdd and on charge light now not light up... and i'm on skype and my mic is very low.... i'm coming through to the other person loud and clear .. but i cant hear them..... help
  • rooner84 Mar 09, 2009
    thanks mate i just sorted out the sound
    as for the flat ribbon cable...
    is this a hard job to get too?
  • 463 Answers
Sounds like the technician that replaced your motherboard and/or CPU didn't hook up the little ribbon connector that powers those LEDs or Speakers.
the mic itself is in the screen part of the laptop, right? And the speakers are in the "bottom" part of the unit?
wow.
Posted on Mar 09, 2009
  • Rob
    Rob Mar 09, 2009
    You'll have to disassemble the laptop around the area in question to get at the ribbon cable. Unless it is absolutely critical, I'd leave it along, especially now that you have sound.
Flashing lights right top of keyboard and left middle. This is no video or booting. tried new cpu doesn't fix problem.
Sad to say a common problem with the dv series in general is a bad motherboard/video card.
Easiest fix is to either send it under warranty, or order a new motherboard as the video card is integrated into the mother board.
Jun 15, 2011 | HEWLETT-PACKARD Pavilion dv5-1250us...
Computer suddenly shut down and won't restart
This type of shutdown problem occurs mainly due to following few reasons, 1) SMPS problem 2) RAM failure 3) Over heated mother board chip(s) or seldom over heated CPU 4) Virus or worm problem or OS problem. 5) Over heated power cords
Do the following steps one by one (to detect the exact source of problem) First replace the CMOS battery, change SMPS, check power cord, run the PC directly (without UPS), remove the data cable from hdd. if it runs well then set the data cable with hdd, if it does not work then definitely there is mother board/cpu problem. And if it creates same problem after fitting the data cable - change the hdd or format hdd and reinstall os. your problem would be solved.
Jun 05, 2010 | Gateway GT5465E Refurbished Intel Desktop...
Janome 9000 refusing to start
I'll bet it's the fuse. I had the same problem about a year ago.
Mar 05, 2010 | Janome Memory Craft 9000 Computerized...
Power connections for tower led's
The manual in question can be located here
http://download.intel.com/support/motherboards/desktop/sb/d1047103_en.pdf
It is a pdf file, so you will need ADOBE,
I have checked and the pinout for the front panel connectors is there.
May 24, 2009 | Intel D945GTP Motherboard
T2682 power up, just get fast blink on front panle lights.
prb a bad mother board ... look on ebay for a used or new motherboard
Mar 28, 2009 | Computers & Internet
Hoe to install the mother board
first install the processor. then the mother board places in the casing. screw it up. then add ram, hdd, dvd rom. at last connected the power cable, restart cable, hdd light, power light.
Jan 20, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
compdoctor2005@btinternet.com
Dec 10, 2008 | Computers & Internet
Packard Bell 4451 lap top will not power up.
check the back of the power connector to see if it is loose. I have known alot of situations were, if not carefully removed, that power connector in the can free itself from the sodder on the Mother board therefore you wont be able to charge the battery nor boot up. hope that helps
Mar 18, 2008 | Intel Motherboard
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
