Question about Akai Mpc2500 Music Production Center
Mpc 2000 reads ''not enough memory''
I recently moved into a new place...after the move I hooked up my mpc2000...tried to load from the zip and my mp read ''NOT ENOUGH MEMORY''...I changed zip drives...same thing...tried to load from the floppy...same thing...
is it that the memory slipped out of socket and needs to be reseated??? if so...do I need to open the Mp from the top or bottom???
  • 74 Answers
Sounds like you have dislodged the memory, you need to get in the bottom and gently remove the ram and reseat it with a slight click.
Posted on May 06, 2010
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
When i go to format my cf card in the mpc, the mpc does not allow the do it button to be pressed. when i press it nothing happens it does not even blink red.
Check that your CF card is NOT biggerr than the unit allows... read the specs. A lot of equipment is having trouble with the larger memory cards. Unfortunately the smaller ones are almost non-existent.
May 02, 2011 | Akai Mpc500 Mpc 500 Drum Sampler,cf...
How do you wipe out everything and put back regular settings on the mpc 2500
from the akai forums:
to set the os back to factory settings press and hold the erase key till the mpc has booted to the main screen.
to erase the harddisk goto either the load or save screen and then choose utility - there you will find the option to format the hdd.
you can also format the drive (or any inserted compact flash-card) from your computer thru the usb connection, but it is recommended to use the internal format because the mpc can be a little picky when you format it from the outside.
at first i would check if there is any folder or the internal memory is set to autoload and just turn that of or point it to another folder of you choice. that way you can keep the factory delivered sounds. maybe you want to use them later, even if it is just to explore the mpc. the factory sounds can be also downloaded later, but be advised that there are different iterations of the stock sounds, depending on whether your mpc shiped with a 32 or 128mb compact flash card.
also the mpc os is not on the harddrive but in the internal memory. to check the version hit mode-> pad10. latest official version is os 1.24. if your main srceen looks different than in the manual check double and triple before you do anything, because the previous owner might have installed the third party jj os which comes in different versions. some of them cost a lot of money! if you find this check the other forum here for the alternative os.
Mar 05, 2011 | Akai Mpc2500 Music Production Center
I purchased an akai mpc 2500 used and it came with sounds and sequences all ready occupied, how do I delete all these sounds, or restore its factorys settings?
Try holding erase while you turn it on. You may have to turn off autoload also. You'll have to read the manual first ( pages 110 and 114 especially ) available here:http://www.mpcsounds.com/download_akai_mpc_manual.php It depends I think on whether the previous user saved to memory card or the internal HD.
Aug 20, 2010 | Akai Mpc2500 Music Production Center
What sound files can be loaded from a pc to an mpc 500? aiff, wav,mpc...? thanks
Data Compatibility
MPC1000: SEQ, WAV, PGM
MPC2000/2000XL: SEQ, WAV, SND, PGM (Most parameters of PGM file can be loaded.)
MPC4000: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
MPC3000: SND (THRU Computer)
Z4/Z8: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
S5000/6000: WAV only (THRU Computer)
S1000/3000: No compatibility
Feb 21, 2010 | Music
Mpc 1000 beginner
Here is an excellent source of info:http://www.mpc-forums.com/viewforum.php?f=15 Consider joining and posting any questions you have. Forum members are happy to help and have usually had the same problems at one time or another.
Jan 21, 2010 | Akai Mpc2500 Music Production Center
Looking for akai mpc2000 part/n s-11114b * 20 pcs
Try http://www.akaipro.com/content1024 Contact them for the nearest parts distributor.
Jul 15, 2009 | Akai Mpc1000 Sampling Music Production...
Is it a bad idea to fly with my akai mpc 2000?
Good idea to carry it with you. Fluctuating barometric pressure will not affect it.
May 27, 2009 | Akai Mpc1000 Music Production Center
Not reading my floppy disk( MPC 2000xl by akai)
Have you tried formatting the disc using your MPC 200XL?
Mar 20, 2009 | Music
Akai Mpc2500 Music Production Center Logo
383 people viewed this question
Top Akai Music Experts
Michial Gueffroy
drivealot
Are you an Akai Music Expert? Answer questions, earn points and help others
