Question about Emerson EWC1903 19 in. TV/VCR Combo
I have several older dvds recorders which use 4x
I have several older dvd recorders which use 4x discs. I cannot locate supplies of 4x. What can I do? without buying a brand new unit?
The product below is nott accurate but it is a Emerson DVD/VHS recorder
  • 147 Answers
Do you have any "£1" shops in your area, "Pound World", "Pound Empire",etc. We have 3 here. All have old 4x DVDrecordable disks.
Posted on Sep 13, 2009
What kind of blank DVDs do I use to copy an old VHS video tape to the DVD? I have the Sony RDR-VX530. When I put a DVD in, I get an Error message saying that I have the wrong DVD.
According to page 30 of the operation manual, the following information may help;
DISCS THAT CAN BE USED IN THIS RECORDER:
4x-speed or slower DVD+RWs
2x-speed or slower DVD-RWs (version 1.1, 1.1 with CPRM) (Content Protection for Recordable Media)
4x-speed or slower DVD-RWs (version 1.2, 1.2 with CPRM)
16x-speed or slower DVD+Rs
16x-speed or slower DVD-Rs (version 2.0, 2.0 with CPRM, version 2.1, 2.1 with CPRM)
2.4x-speed DVD+R DL (dual layer) discs
(when using DVD+R DL discs, see the instructions supplied with them prior to use)
4x-speed or slower DVD-R DL (dual layer) discs
DISCS THAT CANNOT BE RECORDED ON:
DVD-RWs (version 1.0)
DVD+RWs that are not 2.4x-speed compatible
8 cm discs (mini-DVDs)
DVD-RAM (any speed/any version)
DVD-R DL (dual layer) discs in VR mode
A free pdf copy of the manual for this model can be downloaded online.
Hopefully that provides some insight to your question.
May 25, 2011 | Televison & Video
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
It will not load certain dvd discs
Below is a list of discs that should or should not be used with the DVD recorders.
DVD-R
4x can be used
8x will result in a disc error.
DVD-RW
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
MEMOREX DVD-R
FUJIFILM DVD-R
FUJIFILM DVD-RW
IMATION DVD-RW
IMATION DVD-R 2.0
TDK DVD-RW 2X
TDK DVD-R 2X
The following are brands of discs we DO NOT recommend:
MEMOREX DVD-RW
SONY DVD-RW
SONY DVD-R
TDK DVD-RW 4x
TDK DVD-R 4x
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Feb 07, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Recording error
Refer to your user manual for error codes and troubleshooting tips.
If you cant find the error code then please kindly forward the following:
Disk Type:
Recording Device:
Hardeware Specifications:
May 26, 2009 | Symphonic SR90VE
Gateway AR 230 DVD Recorder will no recognize any of my dvds
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's. Usually any cheep brand will work.
Dec 03, 2007 | Gateway AR-230 DVD Recorder
I cant record
I posted this in another person's question but it is probably relevant to you as well. This model (which I own myself) is outdated and needs a firmware upgrade. You might get lucky and get one from their tech support. However, I heard they stopped shipping them nearly a year ago. As it stands your recorder can only use DVD-R that records at 4x (or lower) and DVD-RW that records at 1x. Any other media is useless. Since 4x media is outdated, it may be hard to find at a major retailer. Let me know if you have any luck fixing this or finding working DVDs as I have had the same issue myself. I simply cannot find 4x DVDs in the store.
Jun 01, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Won't Read blank disc!!
Ok, I talked to Samsung support again today, and they confirm that the firmware update should correct the problem of incompatibility with 1-16x discs. They are going to mail a CD with the firmware update to me, at no charge. They were not, however, able to tell me if the file I had originally downloaded from their website was the same as what will be coming on the CD. Sheesh!!
If I can determine that they are the same file, I will post such info. here later. Otherwise, I would advise contacting Samsung support and requesting a disc.
The phone no. is:
1-800-SAMSUNG (1-800-726-7864)
Mon - Sun : 9am - 9pm (EST)
Apr 12, 2007 | Samsung DVDR120 DVD Recorder
Can't record DVDs
OK. Finally "solved" this problem. You must use the brand name "Maxell" DVD disks, 2x or 4x (maybe 8x). Do not use variable speed disks (e.g. 1x--4x) or 16x. Walmart carries these!
The DVR -RW 2x finally got mine to record. I didn't think this would work, but it did. I am still experimenting with it. Had to download (free) VLC player to get it to play on my computer. Works fine in other DVD players.
Credits to the Sears' repairman, the guy at F., and my patience!
Oct 24, 2006 | Sylvania SREC427 27 in. TV/VCR/DVD Combo
Emerson EWC1903 19 in. TV/VCR Combo Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
