Question about Dryers
Kenmore Dryer not heating
I just replaced the heating Element in my Kenmore dryer. Model #8687310068731 Serial # M90597918 but still no heat....what is the next thing to check? The dryer started out not drying well...needed to run clothes through twice to dry..then it quit heating all together
  • ktmm2 Mar 09, 2009
    Thank you for responding so quickly. So do I call the same place I just got the element from and tell them i need a thermal fuse kit for the same model? I have checked all the ventilation also..that seems good
    Thanks again~!
    Tried the breaker...IF! No such luck....220 to dryer...check! On my way to pick up the thermal fuse kit!
    Thanks again!
  • 163 Answers
Thermal fuse is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Posted on Mar 09, 2009
  • mike cooksey Mar 09, 2009
    just give model # but most are the same,thermal fuse kit should take care of your problem.are you sure you are getting 220 to the dryer.if not sure you may want to flip breaker off and on and see if it sarts to heat.sometimes oneside of the breaker will trip and it will run but not heat.just a tip.
We have a Kenmore electric dryer model 11066962501 that has stopped heating, can we get some help opening and repairing?
might be your heating element that is burnt check the model of your dryer then look upnon youtube to replace the heating element simple and cheaper can buy the specific element with the serial part number on the original part :)
Sep 21, 2017 | Kenmore Dryers
Kenmore dryer model 41791052000, SERIAL # XD1304969
first make sure the dryer vent is unplugged. then make sure you are getting voltage to the heating element.if you are getting voltage to the element then the element will need to be replaced, assuming the vent isnt plugged
Oct 24, 2007 | Frigidaire FEQ1442ES Electric Dryer
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
Mar 13, 2013 | Dryers
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
Dryer runs but wont heat
There are 2 possibilities for this problem.
1. The limit switch is out. The limit switch is located on the heating element on the back of the dryer. This is a small button type part. it will have 2 prongs on it for 2 wires that slide on for power.
2. The heating element is out. This will be on the back of the dryer and depending the model it should be a long metal piece that has metal elements inside of it to heat the dryer. or it could be a large round unit. these can be tested with an om meter.
The limit switch will be the cheapest to start with on replacing.
If you need further assistance please do not hesitate to ask. I will need the make, model, and the serial number of the unit to help you further. the model and serial number can be found by opening the dryer door and looking by the hings. there should be a sticker with this information on it.
Apr 13, 2010 | Kenmore 64852 Electric Dryer
No heat in my kenmore elite dryer, model 11085872401(electric)everything else running, tested voltage at 240 ok. pulled the heating element. it looks like a small crack in the middle. Does that have any...
It means your element needs to be replaced, take it to the Kenmore parts store nearest you, and they will confirm that, and you can get a new one there unless they have to order one in.
Be sure to have the make and model and serial number of your dryer with you.
Dec 15, 2009 | Kenmore Dryers
Dryer isn't heating. It turns and blows air but
make sure lint screen and vents are clean. next shut off electric and check heat element for broken element. then get model # and serial # order and change thermocutoffs located on heater box and fanhousing ck these steps one by one
Dec 09, 2009 | Kenmore 75962 Gas Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly.
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Jun 14, 2009 | Kenmore 63942 Dryer
Dryer won't heat--element replaced; tumbles fine
Before you purchase any more parts, you should have use of a multi meter. If the dryer is not heating at all, and of the following parts could be bad.......Operating (cycling) thermostat, high limit thermostat, thermal fuse, timer, or motor centrifugal switch. All but the motor switch can be easily checked with the dryer UNPLUGGED using the ohms feature of the meter.
May 03, 2009 | Dryers
Dryers Logo
234 people viewed this question
Top Dryers Experts
