My Toshiba laptop computer starts up fine, but shortly shuts down
I tried to do a recovery, but the computer won't stay on long enough to all me to do it.
  • 1 more comment
  • edge29arch Mar 09, 2009
    Satellite 1955 S803.
    I use an external cooler under the unit and it doesn't seem warm to speak of.
    Is someone available to answer my questions now?
    President:
  • 2,653 Answers
What model is your Toshiba?
Does it feel like it's getting hotter than it should?
Posted on Mar 09, 2009
  • RescueTechLA
    RescueTechLA Mar 09, 2009
    Try reseatting the memory and test to see if that changes anything.
    Usually this problem indicates an overheating issue, but since you're using a cooler and it doesn't feel warm then the issue points towards memory problems or more than likely a problem with the motherboard.
    Try entering the bios and just let the computer sit to see how long it works before shutting down.
My Toshiba laptop keeps shutting off after a minute or so . It wont even stay on long enough to boot from a disk . checked all cords &battery . They are fine . What else can I do ?
too much dirt in the mashine, or your gpu is gone, sorry.
cpu has heat check before starting.
Go too utube for info how to help get the mashine up and running again. called reballing.
Apr 05, 2014 | Toshiba Satellite Computers & Internet
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
Toshiba A60 equiam will not boot from original recovery disk
Try reseating the RAM modules and then try the recovery CD.
If it still fails, take the RAM modules out and take them to your friendly computer repair shop and get them to test the RAM.
Mar 04, 2012 | Toshiba Computers & Internet
Will turn in but won't really start up, message pops up sayin I have problems on my laptop but it can't fix them? Read description
When your toshiba splash screen is showing on startup, press F8 continuously, then you should get some options, go to the one that says safe mode. After loading windows in safe mode click start, search, and type system restore. Open system restore, find a date where your pc was working correctly and click restore. If this doesn't do it on the toshiba spash screen (if you have a new enough laptop) there will be an option called system recovery usually f11 key, this will restore your pc back to its factory state and should resolve any problems your having. If you don't have that option go to https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp and see if you can order a set of recovery disc's for your model, they usually run from $25-$30. Hope this helps.
Mar 01, 2012 | Toshiba Computers & Internet
My Toshiba Satellite L300-D won;t get poast Startup Repair page. Keeps defaulting to Startup Repair and then says "Windows cannot automatically repair your computer". It all started with a folder...
Your Hard drive is faulty which means it wont go any further and loops back trying to fix a problem it cant do. you can either replace the hard drive and install everything from scratch or send it in to a computer repair shop to do it for you. Kronoguy
Aug 02, 2011 | Toshiba Satellite Pro L300 Notebook
Won't start goes to XP window and shuts off then when you try to go to safe mode or start windows normally it also shuts down. Does the same if you try to go to last known good configuration
Sounds like a problem that I've had with a bad battery. I ended up taking the battery out and running straight from the adapter. It could also be a board short or virus. You might have luck, if you can get it to stay on long-enough, by hitting F2 at power-on and changing your boot order to the optical drive first and try booting from a recovery disk. I hope this helps.
Feb 23, 2010 | Dell Latitude C610 Notebook
Laptop start up problem
Have you tried performaing a recovery ?
Feb 15, 2010 | Toshiba Satellite Pro M10 Notebook
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
After replacing hard drive, computer wont stay on long enough to use recovery disk
You can not use a Dell cd, but if your XP license is on the bottom of the laptop, you can use a Win XP cd (borrow one from a freind) to reinstall the OS.
Sep 28, 2008 | Toshiba Satellite A75-S211 Notebook
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
