Question about HP Officejet 5610 All-In-One InkJet Printer
Scanning and copying
I have been unable to scan or copy off my printer. I can print ok but nothing happens when I try to use either of these functions. I have a slight crack in the glass and I'm wondering if that would have anything to do with it. It worked for a while after the crack happened but all of a sudden it isn't which is why I'm unsure if they are related. Please let me know if you think this could be the problem and how I can go about getting new glass for it. Thank you.
  • Kristie steiger May 11, 2010
    Does it give you any error messages? You should be able to send it in to HP for repair on the glass.
SOURCE: scanning document leaves streak down right hand side
Backu
Thanks for the tip...the problem is NOT a black line but a wide yellow line on the right side of the paper. It starts out about a quarter of the page in width and diminishes in size to about a half inch in width after many repeated scans.
The glass IS clean , and even when the glass had some smudges here and there, I never had a yellow stripe problem!
Scanner bulb is bright and even the entire length of bulb (no dark areas) so I don't think it is the bulb!
Rowboat
Posted on Dec 26, 2007
bunnydawg
  • 5158 Answers
SOURCE: cleaning the scanning glass
Hard to get a smudge inside but basically you take it apart and clean the inside of the glass
Posted on Aug 31, 2008
Riztech
  • 731 Answers
SOURCE: Problem scanning or copying
Hi BOB
Click on the below link "Solve my problem" for the solution
Solve my problem
Thanks and regard
Rizwan
rizwan84tx@gmail.com
Posted on Dec 06, 2008
ydja
  • 3 Answers
SOURCE: HP 5510 Scanner/Copier/Fax Stuck
I had the same problems some months ago. I only solved it when I deleted the printer settings from my computer and reinstalled the software, making sure that I installed all the components from the CD. Also make sure that the printer is on fax default setting when you are using it as fax. You can check this by going to My Computer then Control Panel, then choose Printers and Other Hardware then choose Printers and Faxes. You can then set as default hp Officejet 5500 series fax. Hope these suggestions help.
Posted on Jan 21, 2009
  • 4 Answers
SOURCE: HP L7680 scanning problems on MAC
I think that there is a problem with your driver, uninstall and reinstall your drivers. should work.
Posted on Mar 02, 2009
I can't copy or scan. Printing works fine. When asked to copy , the display says copy in progress but nothing is happening. The same is true when trying to scan the display says scanning in progress but...
Did you try to scan from ADF or Flatbed glass?
Now as its not copying then it can be hardware issue so we can try to reset the printer and for that
1. Unplug the power cord from the back of the printer while the printer is ON
2. Hold and press the # and 6 key at the same time and while holding them plug in the power cord you will say that the printer turns On and there may be reset message on the screen of the printer ..release the buttons
its around 2 minutes process and it will reset your printer
If does not help then please get back to me
Apr 08, 2011 | HP Officejet 5610 All-In-One InkJet...
Nothing happens when i press scan button
Nothing will happen unless it's connected to a computer with scanning software running. If you want a copy you press copy and it will scan and make a copy, but if you want to scan you need the software to tell it how to scan, what you're scanning, and how to save the scanned image.
Feb 19, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Unable to cop
You can not use the copy feature if your printer is "printing". You can scan while other is printing simply because scanning is not using the printer's print heads. Therefore if you are printing, you can not copy at the same time.
Is your printer printing OK? So you should be able to copy as well. Press COPY button when the printer is ready. Basically, you have the Copy (Black) and Copy Color options. If you have 1 option only, pressing COPY makes you choose black or COlor using the keypad selector. Just choose any option and press OK or START.
Nov 20, 2009 | HP Officejet J5780 All-In-One InkJet...
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
My all in one printer/scanner is not scanning. prints and copies fine, but does not scan
Form your issue that you are able to print and copy but unable to scan it is very clear that it is a software issue. Copy and scan fuctions work this way.
Copy - completely related to hardware.
Scan - related to software
uninstall and reinstall the full version software from Hp for the operation system of your computer.
Aug 23, 2009 | HP DeskJet F4280 All In One Printer InkJet
Unable to copy from scanning bed
There is probably a little switch that gets tripped when the document feeder is in correctly. This is preventing you from scanning from the glass.
Jun 02, 2009 | HP Officejet 7310 All-In-One Printer
Lexmark X6150 Inkjet - Problems Communicating with Printer
For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
Scanning function doesn't work
If it copies fine, then it IS scanning. If you are trying to scan to your computer then you will need to open the program and follow the instructions.
May 24, 2008 | Dell 924 All-in-One InkJet Printer
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
