Question about Maytag PAV2300 Top Load Washer
Replacing lid on old Maytag toploader
I want to transfer the lid from one old Maytag top loader to another. The lids are "hinged" with little balls that fit into a depression in the side of the lid and into a corresponding depression in the top of the machine. How can I pop the lid out of the "old" machine without ruining it and pop it into the "new" one"?
Thanks
Hal
  • hweaver Mar 10, 2009
    Thanks. I'll try this tomorrow and let you know how I make out.
    Hal
  • hweaver Mar 11, 2009
    Amazing! It went just as you said. I did have the ball pop out several times, but we finally got it in.
    Many Thanks.
    Hal
  • 163 Answers
Pull the lid back at angle and they will fall into tub.put one side in wet the other side and try to put ball on lid and slide it back into slot for lid ball.may be a hasssle but it will go into place.
Posted on Mar 09, 2009
  • mike cooksey Mar 11, 2009
    Glad I was able to help.
How do I replace a lid switch for model # awm392w
I own 20 speed queen top loaders that the same machine as yours.
they are 19years old and have never had a lid switch go out.
the problem is the arm that activates the switch gets bent and can activate the switch. to fix take the 2 screws out of the left side of the lid hinge then tilt the lid to the side and slide the right side out. this is the arm that activates the switch . looking at the top of the lid bend the arm up just a small amount. them put it back on the machine and try it you may have to bend a little more to make it work.
Jan 18, 2013 | Speed Queen Washing Machines
Maytag MTW5770 TQ model. 3 years old. You have to drop the lid hard or push on it to get the machine to recognize the lid is 'closed' and can then start the agitation and rest of cycles. It does...
Some of them have a mercury switch that has been bent so it doesn"t make good contact with the liquid mercury. If you can find it you can bend it back. It has to be on the door or an arm under the door or door hinge.
If you know how, you can raise the washer top using a flat knife type of tool to move springs thru the gap between the washer top & the lower front piece. (assuming it's a top loader)
In a front loader it's still near the door.
Jun 26, 2011 | Maytag MTW5770TQ Washer
How do I get top of my washer..Maytag Centennial ...Model # MVWC400VW1...to get to the lid switch?
This model Maytag is actually manufactured by Whirlpool. To access the lid switch on this particular model, all you should have to do is remove the operator console. The console has a retaining clip on each side holding it to the cabinet top. To release these clips, simply take a putty knife and slide it under the left and right front corners of the control panel push straight in towards the back of the washer. The clips will depress, allowing the operator console to be lifted up. The lid switch is mounted next to the left lid hinge. Refer to the "Top and Cabinet" parts illustration, Item 6 at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWC400VW1/3048/0153200?pathTaken=&prst=0&shdMod=MVWC400VW1
Some other websites you may refer to for parts include:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: If you model number does not cross reference to these sites, use the part numbers fromthe Sears websites as your search criteria. Often, the model numbers may not be included on some websites (newly added models), but the part numbers will.
HINT: In some cases, what may appear to be a bad lid switch, may only be an actuator adjustment. The acutator on these models is the rod attached to the left lid hinge. You can bend the rod slightly to adjust the contact with the lid switch, or it may be tightened as necessary. If the switch toggles (clicks) by hand with the actuator rod removed, the switch typically is not bad.
If you need to remove the entire cabinet to access under the lid, the following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If you need further assistance, please post back and let me know. I hope you find this information helpful.
Apr 21, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
The cycle stops at final rinse and water is left in the drum.............until I cycle the knob and depress to activate.
tighten the hinge screws on the top left of the lid. If that doesn't get it started hit the top to engage the lid switch which is hooked into the left hinge on a whirlpool. if its a maytag, its in the center of the rear lid and you must remove the consoles rear to access the lid switch
May 03, 2010 | Maytag MAV7580E Top Load Washer
The button that engages when the lid is shut
512 are some of the best maytag made. the lid assemble is also you off balance . you should purchase a lid sw/ assemblyl and replace it . it's not a hard job .the lid will pop off if you pull it hard / do not lose the lid balls / this will let you get to the screws . p s order extra lid balls when you get the sw . they some time break . mm
Nov 22, 2009 | Refrigerators
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
Cycle won't start
the lid is not making proper contact with the lid switch, easy repair.
the lid is held to the maintop with a set of hinges. The left side hinge actually doubles as the lid switch actuator. so youll need to lift the lid, and feel for the opposite end of the hinge assy. when you feel the metal "arm " for lack of better word. youll need to bend it slightly towards the back of machine( usually use a hollow shafted screwdriver) as you bend backward the lid will want to close, so apply a little pressure. Your bending the "arm" to make better contact with the switch which ismounted tothe underside of the main top assembly. Before starting open and close the lid a few times and listen for the "click" of the switch activating. then recheck after bending youll hear a big diff
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
The Error display is "OP"
I had that same problem. I lift the top up by using a screwdriver and pushing in clips that are in the front. Lift lid carefully from the front. A hinge in the back will hold the back of the lid. Look where locks are located and see if they are connected. On my washer the connection was barely on. I reconnected the lock and have not had problem since. Good luck.
Oct 28, 2008 | Maytag Neptune FAV6800A Top Load Washer
Top load lid repair
put one of the plastic balls in place on one side of the lid, hold the lid against it to hold it in place. then put the other ball in the other side indention and push the lid down on it until it pops in place. it is a little tricky if you have never done it b4.
Jun 27, 2008 | Maytag SAV2555A Top Load Washer
Maytag Neptune Lid Lock Replacement
I have replaced my right lid lock twice and the second one just went bad. The left one does not matter, only the right one tells the washer the lid is locked. I think the bleach cup is the problem, bleach corodes the metal contacts in the lock. Try removing the plug and cleaning the contacts. I am going to bypass this lock I am not buying any more parts for this unit!
People have reported replacing this lock several times in unser two years.
Aug 30, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag PAV2300 Top Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
