What is the best way to go about solving a Playfair word square(i.e. to find the keyword)? It seems trial and error works fine, but how does one speed up the process? Regards, Ray Steiner
I have a DOS program which will search a word list given one or two encrypted/unencrypted pairs of letters, displaying all words which would be valid Playfair words.
You are quite welcome to the source and/or object. You do need a good word list for it to be of much value.
Email me if you don't object to this despicable form of cheating.
Regards -- John Gardner
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Playfair squares:
Solution #2
posted on Aug 02, 2007
Brad - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
: What is the best way to go about solving a Playfair word square(i.e. to : find the keyword)? It seems trial and error works fine, but how does one : speed up the process?
In the context of crosswords, to look beyond trial and error seems rather pointless, as normally compilers will give you just enough information to deduce the code square with as little redundancy as possible: so the keyword will typically be fairly obvious once you have sufficient pairs of letters.
The only trick I know of is to look for sequences that have a high probability of being in the alphabetical string that follows the keyword: e.g. BCD, KLM, XYZ etc. The problem is that naughty compilers are liable to use keywords with as many letters of the alphabet as possible, like DERMATOGLYPHICS or even VOLKSWAGEN-TRIUMPH.
Long before it provided inspiration for crossword compilers, Playfair was a code of practical importance: e.g. it was used by the British army between 1900 and 1914. Derivative forms of the cipher were still in use in the second world war, as is recorded in "Codebreakers - The Inside Story of Bletchley Park" (OUP, ISBN 0-19-285304-X). Gaines's "Cryptanalysis" (Dover, ISBN 0-486-20097-3) is another book with a chapter on real-world Playfair decryption techniques. Here's an example from it (the cleartext is known to start "enemy agents"):
OS CF WD OG DR AN PO AS OA DH SD EH XK FU CN DR MS UK SD
-- Ross Beresford Author of TEA - word search for crosswords |_|_|_|_|_| Voice/FAX: +44 118 9344153 &Sympathy - crossword grid construction |_|B|_|L|_| Email: Web: # |_|_|_|_|_| Bryson Limited, 10 Wagtail Close, Twyford, Reading, RG10 9ED, UK
