Question about Brother MFC 8820D All-In-One Laser Printer
My paper drawer is broken; how do I get a replacement for a MFC8820
  • 526 Answers
We can order one for you if you like, the cost will be $30 plus shipping
Posted on May 07, 2009
Hp 1320 drawer stuck
hi
The paper tray has a small lock at the bottom of the tray which is broken or dislocated hence try to fix it if its dislocated or you may have to replace the try itself. But still you can use it by adding paper to the full of the tray's capacity and pressing it gentelly downwards and push it back into the printer.
May 05, 2014 | HP LaserJet 1320 Printer
The paper in Ir 5000 drawer could not go up
where drawer it is ? if drawer 1 and 2, may be the drawer motor doesn't work or rope lifter or lifter gear has broken, the position is behind of the drawer,
May 10, 2011 | Canon Office Equipment & Supplies
Hi the paper roller on the legt hand side of the printer is broken and it drawers the paper in on an angel. Can you please tell me where I can get a replacement and fixed? Thank you Tania
You would need to either get a broken one with this roller intact and replace the part, or contact lexmark for a replacement ( it it still under warranty btw?). Then take it to a computer repair shop to have it fixed
In total,this would probably be more than the cost of getting a replacement printer
Feb 07, 2011 | Lexmark X1150 All-In-One InkJet Printer
Paper set
Take out the paper drawer in the upper portion left of the feed roll should be a black switch, this gets knocked off alot due to not locking down the paper in the drawer when loading. If the switch mounts arent broken you can try to put it back in position, or do what I do to save time and $$, just tape the switch "open"and tuck up above cassette cavity.
-Carl, please let me know if this helps.
Jun 26, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Hi. I've a Dell 1600n printer. There is plenty of paper in the drawer, but message says No Paper/Add Paper.
Remove the drawer then insert again.. if the same problem.. clean the sensor maybe its broken.
Jun 15, 2009 | Dell 1600n All-In-One Laser Printer
Ricoh Aficio AP410 paper tray
Try this links for the parts of Ricoh printer:
Ricoh USA
The Printer Place
Thanks
Scott
Jan 29, 2009 | Ricoh Aficio AP410N Laser Printer
''place paper in drawer''
Sounds like a paper sensor ; A little black arm that senses paper tray is full, when the tray lifts into position. You might pull the tray and with a flashlight look for any broken parts. I have seen these break when paper jams are removed. This is a Toshiba 2860 correct?
Nov 18, 2008 | Office Equipment & Supplies
Paper
If the paper size tab inside the drawer is out of position, even by 1/8 inch, you will have this problem. Also, the drawer itself could have a flaky/broken paper indicator switch (shows how much paper is left). I have had both these issues. On the first, I just slid the adjuster back in to letter position. The second, however, took replacing the drawer.
Nov 18, 2008 | Brother HL 5140 Laser Printer
Brother MFC 8820D All-In-One Laser Printer Logo
53 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
