Question about Nintendo Professor Layton & the Curious Village Games for DS
Stuck Where is the sewer im supposed to search nit. I can not find it
You go down the manhole on puzzle number 106 park road
Posted on Mar 09, 2009
Bathroom sink smells strongly like sewer when water runs fast.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
Oct 15, 2012 | Plumbing
WATER LEAK BOTTOM OF UNIT
If this is a central AC, the
condensation drips off the cooling coils into a pan. From the pan, it is suppose to either go into a drain directly or into a sump, which in turn pumps it into a drain. Dirt or mold frequently plug the drain out of the pan or the drain line itself. You need to clear the drain with a wire or forced air. If there is a trap in the drain line, it may be plugged. If there is a trap and the line is not draining from the trap into a sewer, then I suggest you remove the trap, which is intended to block sewer gas from coming up the drain line. If it doesn't drain into a sewer, there is no sewer gas to block and the trap is unnecessary. The credulous building code requires the trap, regardless of whether or not the unit drains into a sewer.
If you are talking about a window unit, the problem is similar - the water is being blocked from where it is supposed to drain. With a window unit the water is usually picked up by the fan that cools the
condenser (hot coils) on the outside of the unit. The fan sprays the water on the hot coils and evaporates it so it doesn't drip out of the unit.
Oct 04, 2012 | Goodman CKL49AR49 Air Conditioner
Old game for computer
I thinks it's called sewer run, lol, and you can get it here >>>>>>>>>
http://wareseeker.com/Games/sewer-run-1.zip/3b4d1b1eab
Regards.
Jul 10, 2009 | Microsoft Windows 95 for PC
HOW DO I CLEAN OUT THE LINT TRAP ? THE MACHINE IS @ 6 YEARS OLD AND NOW I AM HAVING SEWER PROBLEMNS CAUSED BY LINT FROM THE WASHER.
I did not fix the problem, I called a plumber and fixed the sewer. So I will still have a problem with the lint trap on the washer. It is supposed to be self cleaning, but I have my doubts.
Mar 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Cant get to the sewer
have to go down the man hole to get to this
Mar 18, 2009 | Nintendo Professor Layton & the Curious...
Sewer pipe
Hi sir simon,
I'm Harvey the Master Plumber.
Your problem is: You're installing a new sewer pipe and wonderind how much fall it needs
1/4" per foot. You can buy a plumbers torpedo level to make it easy. You'll see 4 hash marks on the tube. Center the bubble in the middle and the pipe is level, so just adjust the pipe so that the bubble is just touching the outer line and you've got 1/4". No measureing. And it only costs a few dollars.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 03, 2008 | Plumbing
Nintendo Professor Layton & the Curious Village Games for DS Logo
67 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
