Question about Lightning Audio Amplifier, B3.200.2 Car Audio Amplifier
I have a lightnig audio amp its 760 watts not sure whats wrong
I have a lightnig audio amp its 760 watts i think the protection light is on and no audio comes out alls my wires are right it worked for a while than it stopped
    Problem Solver:
  • 8 Answers
Did it stopped working ?
check your main fuse line under the hood ?
you should have one ! replace it ?
know if it works fine out what ohms is your amp best plays at!
and connect the correct woofer ohms ..
for that power at the most two 8 inch woofers or one 12 ich thats pushing it!
Posted on Mar 10, 2009
Green light comes on for a sec the red light comes on,1200 watt sony xplod amp 10'' Orion sub,I think the subs right around 3000 watts. What's wrong?:(
Your Sony Xplod amplifier turns on briefly (green light) then possibly senses a mismatch between the nominal output impedance of the amplifier and impedance of your Orion sub and goes into protect mode (red light) to prevent internal damage.
Jul 19, 2014 | Car Audio & Video
My Pyramid Arctic Amp 1000 watt was working fine for about a month then one day the protective light came on and stayed on as long as the amp had power. So now it wont give any watts to my two 12's....
Troubleshoot to the component level to find out what is causing protect mode. A short in the output stages as a result of overdriving is one likely suspect.
Jan 14, 2018 | Pyramid PB1615X Car Amp
Is something wrong with my amp if the protect light stays on or is it the wiring?
It could be the wiring. Sony amps will go into protection if the ohm is to low. They usually like to see 4 ohm or higher. Unplug your speaker wires and see if it still stays in protection. If it does could be an internal thing in the amp. If it isn't rewire subs in series not parallel.
-david
Nov 09, 2010 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
I have a 1800 watt amp but the red light is on but it dose sound like the bass works but not it its prime
the red light is for power in protect mode it should be orange and it will not emmit sound if you think you should have better sounding bass or more bass you can try to play with the gains on the amp or possibly if you have the negative or positive hooked up wrong from a speaker to the amp this will cause the bass to be lower and somewhat distorted double check your positive and negative wires from the speaker to the amp and make sure they are correct
Feb 28, 2010 | Kenwood KAC-9152D Car Audio Amplifier
2000 watt american legacy amp protection ligh wont go off
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Jul 01, 2009 | Lanzar MXA422 Car Audio Amplifier
Power problem amp
Sounds like its going into protect mode-try disconnecting the speakers from the amp entirely and turn the system on if it stays lit up- then ya know its the speakers (one of them at least) thats making your amp shut itself down. If thats the case look into replacing the speaker thats causing the problem.Also make sure that you have sufficient wiring to your amp - at least 8 gauge if you can. check all terminals /power/ground make sure everythings connected tight and not grounding out anywhere
Mar 29, 2009 | Kenwood KAC-9152D Car Audio Amplifier
I have an xploid 760 same amp wit ha 800 watt sub. eb=verything should work fin. but the same prob when i turn up the valume the overcurrent kicks on
use a bigger ground wire for amp and protect mode will stop clipping and shutting amp off also make sure power wire and ground wires aren't the same size ground bigger .............if this doesn't help change settings on amp to lower power
easiest way to set amp is (turn the knobs on amp all down turn up your system to the level you listen to normally and then set the amp knobs for bass turn knob slow to set properly but i think the ground needs to be bigger and maybe moved to a new location
hope this helped
Mar 03, 2009 | Sony XM-2150GSX Car Audio Amplifier
Support Question about RMS
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
No response from amp
it sounds like you have a bad ground make sure its on the froame or body and make sure any rust or paint is sanded or scraped off
Feb 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Lightning Audio Amplifier, B3.200.2 Car Audio Amplifier Logo
116 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Richard Lukszys
Richard Lukszys
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
