I have a Kenmore 44082 front loading washer which we bought in 2005. It just started failing by running for 20 seconds, stopping for a minute or so, running fo 20 seconds, stopping for a minute or so,......and never really washing. The error light displays??
  • ronald_quick Mar 21, 2009
    There are no error codes. I had Sears come out and they wanted to change the door latch mechanism. I went ahead and did so and get the same results.
  • Washing Mach... Master
  • 3,361 Answers
Are you getting any codes?
This is the central control unit sending messages to the motor control unit to make speed adjustments.
Could be from loose wire connections, loose,dirty or corroded ribbon connections or a defective CCU or MCU board.
Unplu the machine.
Remove the front panel and the top panel to access your control boards and check all connections.
Remove them and re-install them.
Look for a smashed or broken wire.
Posted on Mar 09, 2009
  • steve
    steve Mar 21, 2009
    Your motor speed board is bad.(mcu)
  • 163 Answers
What is the error code
How do i take my kenmore 44082 series apart
with machine the top is a flat wooden paneland at the rear of machine is two little screws one at each side remove this will expose the top of machineif no belt is visable then its broke and lying at the bottom of machine,as for the pump this sits at the bottom of the drum ,you dont tell me your problem,so,i dont know how to help you.adrianxxx
Aug 08, 2012 | Kenmore 44072 Front Load Washer
I just replaced one of the suspension springs in our Kenmore 417 frontload washer. When I turned the washer back on and tried to run a load, it will run for about 5 seconds then stop for about a minute...
can you give me some explanation on what you did to replace the spring?. did you have to take the washer apart?. check the wire. maybe you forgot or did not plug all the way a connector. or came apart. my impression is that something came loose and the computer is not detecting a connection.
Feb 09, 2011 | Kenmore 44042 Front Load Washer
washer fills up with water when washer is off
Dec 11, 2009 | Kenmore HE2 Plus Front Load Washer
My front load Kenmore washer 44082 does not start. just buzzes and displays ERR.
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 04, 2009 | Kenmore 44042 Front Load Washer
Washer aggitate for 20 seconds then stops, starts
This could be your control switch. Remove the front cover at the top that has the dials on. Check main switch unit, it probably needs to be rebuilt, about $35 or installed new.
Nov 01, 2009 | Kenmore 22422 Top Load Washer
I own a kenmore top loading machine model number 110 10 amp 60 hertz 120 volts the machine gets power and runs but the big control knob that controls the diffrent cycles is running only about 20 seconds...
sounds like you should replace timer (big control) timer motor is part of timer. Is timer knob speeding thru cycle that fast or just start/stop.
110 is manufacturer code for whirlpool, number after decimal is model number. tech sheet avail inside console by unsnapping left and right console covers and removing hidden screw at front bottom corners, pull forward slightly then fold console back (hinged at rear top).
Apr 26, 2009 | Kenmore 22642 Top Load Washer
Kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Jan 17, 2009 | Kenmore 44102 Front Load Washer
Kenmore 44082 front washer will not drain or fill
e23 is not a valid code.
Please re-check and post if you still need help.
Jan 09, 2009 | Kenmore Energy Star 44092 Front Load...
Kenmore Front load washer didn't complete the cycle.model #44082
Do you still have your owner's manual that came with the Kenmore washer? Look under troubleshooting your Kenmore washer.
Jul 06, 2017 | Kenmore 44102 Front Load Washer
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
