Question about Linksys Wireless-G WRT54G Router
Trying to hook up linksys help
Old home comp died new laptop have linksys router model wrt54gv2.2 modem is bridged to linksys need to get in and connect with username and password i beleave i need help
they said my warranty on linksys is up would have to pay forty dollars but said if i went in and did it myself i would be fine please help
  • 135 Answers
Connect your computer to one of the LAN port of the router, access the IP address of the router (IP 192.168.1.1), for the connection type choose PPPoE, type the username and password provided, Check the IP address under status (WAN section if the IP address is 0.0.0.0 then click connect)
Then check the Internet connection.
Posted on Mar 09, 2009
I tried to set up my wrtg54 linksys with my new motorola modem from at&t. The linksys says it cannot find an internet connection. Of course, when ethernet is taken out of comp to plug into router, the...
Good day,
The AT&T modem(Motorola), is actually a modem and a single port router.
To work with the Linksys it must be set up in bridge mode. Then let the router make the decisions.
AT&T tech support will usually not help you if the router is not there product.
On Google, there are many sites that will help with this issue.
Unless you've already done it, you should contact AT&T by phone and request tech support on setting up your modem. They will talk you thru the whole setup, including testing but without the router.
Then proceed with the steps thru Google.
I do not know the settings for your specific router, but the forums will usually help.
I assume you're on DSL. Make sure they know that. Cable settings are different.
Dec 14, 2009 | Linksys Wireless-G WRT54G Router
I have an old Linksys WRT54G v1.1 wireless router - trying to connect to my new DSL line using a motoral modem, to my Dell laptop running XP. help!!!
Is the motorola currently surfing and are you trying to add the linksys to it? If so you will need to go into the motorola and set it to bridge connection under connection type found in the expert mode of the modem. Then you will add the linksys and input the username and password in the pppoe connection type. Once the info is save click on the status tab and click connect. Hope this helps
May 16, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
I have a Linksys WRT54G router. The power went out the other day and I haven't been able to establish a connection since. I can connect when I run cable from the modem to the cpu, but not if I try using...
what is the model of your modem? if you said that you are able to get online when your computer is hooked up to the modem only, then it indicatest that your modem is not yet in bridge mode. Putting it in bridge mode will make your modem a "pass through" device thereby causing no conflicts in asking for ip add/connecting to your ISP. when your modem is in bridge mode, you should not be able to get online.
after setting your modem to bridge mode, connect your linksys router. if you have a pppoe connection, or one that uses username and password, have that set up in your linksys router. at this point, your router will be the one to ask ip adds from your ISP.
you could also visit this site, http://www-ph.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=PH/Layout&cid=1166859677881&pagename=Linksys/Common/VisitorWrapper&lid=7788193882H13, for further configuration of your router. as for your modem, try to call your ISP on how to set your modem to bridge.
May 05, 2009 | Linksys Wireless-G WRT54G Router
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
Apr 10, 2009 | Westell Wirespeed LiteLine 6110 Modem
Linksys wireless-g broadband is not hook up to comp. the cord from cable modem the by pass is on to the comp.
If you want to use the linksys, you need to connect the cable from the modem to the linksys, then use another cable to connect the computer to the linksys. If it does not work, call linksys technical support, if they cannot help try this http://technicalsupport.blog.friendster.com
Feb 18, 2009 | Linksys Wireless-G Broadband Router
Router worked. Modem quit. Now it won't work with new modem
Ok in this case the problem is more than likely a generic one for all modems. All modems like to bind themselves to whatever device you have initially plugged in when you plug in the power cable for the modem. My guess is you had the pc hooked up directly to the modem and then plugged in the poewr cable to the modem.
To fix this you need to unplug the router and modem cables for 2 minutes. Plug in the modem with it being hooked up to nothing but the wall [Power Cable and Internet Cords hooked up only; no pc yet]
Your router is probably not need to be bridged so there should be a small hole somewhere on the router normally on the back or bottom saying reset. Press and hold that button with the router only plugged into the power no internet or pc [Although it doesnt matter if the pc is hooked up to the router] for at least 10 seconds. This will cause the router to reset to the factory default settings undoing the bridge. After this time the modem should say it has internet and whatever else except a activity light and similar things.
What you want to do now is unplug the router from the power and hook up the modem to the router and then plug the power cable back into the router.
After all this you should be able to go into the pc and access the router and set up the settings you like or need for the router if you want. Otherwise you should have internet again.
Jan 13, 2009 | Linksys Wireless-G WRT54GS Router...
Re-installing my linksys
Before you can use your linksys router again, you must configure first your AT&T modem under bridge mode. If the AT&T modem is already set to you may connect the devices (modem router and PC) must be switched OFF first.
after the devices had been connected,...
1) turn ON the AT&T modem first, wait for the DSL light to stay solid
2) turn ON linksys router,wait for the lights to stay solid
3) turn ON computer,wait for your desktop screen
4) try to access Internet Explorer
Nov 13, 2008 | Linksys Wireless-G WRT54GS Router...
Westell router modem hook-up
No. That device is a DSL gateway. It is exclusive for dsl connection.
You can use a Linksys WCG200.
Mar 23, 2008 | Westell Wirespeed VersaLink...
Linksys Wireless-G WRT54G Router Logo
61 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
