Philips Magnavox MWD200G DVD Player
My DVD player is reading Disc error . What Does that mean ? When I put a dvd in it just keep on turning and then it will come up with the message disc error.
  • jcrawford906 Mar 12, 2009
    Thank you for the help, because I did not think to clean the optical lense, but now when I put in a dvd it will not turn.
    Problem Solver:
  • 15 Answers
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
Posted on Mar 10, 2009
I need pass code for my Universal remote so I can program my Magnavox MWD 200G DVD Player
looks into the manual of your Universal remote, there will be alot of code for different devices. I would give a try with any philips codes.
Feb 28, 2011 | Philips Magnavox MWD200G DVD Player
The DVD player is saying there is a disc error
it either means that you need to clean your disc(s) or there is something loose inside making it malfunction
Dec 17, 2009 | Philips Magnavox DVD/VCR Dual Player
My dvd player is reading no disc
Either your lens of the dvd player is dirty or the dvd's you put in have no data on them
Mar 30, 2009 | Philips Magnavox DVD/VCR Dual Player
No picture or sound magnavox mwd200g dvd player
on the side of the tv mostly there is a button for dvd mode you will have to press that button to reach in dvd mode.if no such button then its the cables fault or the wires are not connected properly just check out this link for connections
For tv/dvd /vcr connections
http://www.funai-corp.com/support/setup.aspx?prod=dvd2tv2vcr
For tv/dvd /vcr question answers.
http://www.dvddemystified.com/dvdfaq.html#1.27
Mar 02, 2009 | Philips Magnavox MWD200G DVD Player
No disk inserted
you could have a dirty laser lens try a lens cleaning disc. if that does'nt work you have either a bad laser or spindle motor.
Feb 13, 2009 | Philips Magnavox MWD200G DVD Player
I place dvd in and after loading it saids please eject the disc playback feature may not be available on this disc. i tried one of my dvd's, and it did the same thing.
well, maybe by having the player un-plugged overnight i will see a difference tomorrow, but for now i had to buy an upgrade DVD player, the laser eye cleaners only clean small scratches in the eye and the main problem from that is when all of the dvds played either skip or freeze, in this case the dvd will not spin or load the disc menu, good luck!
May 06, 2008 | Philips Magnavox MWD200G DVD Player
Audio out problem (magnavox MWD200G)
yellow to yellow that is video and that is ok.
red and white are the audio chanels left and rigt try to change it and your soun will be ok
Feb 07, 2008 | Philips Magnavox MWD200G DVD Player
Help with Magnavox MWD200F
The lense is proaly gone or mechanism disrupted
Feb 26, 2007 | Philips Magnavox DVD Player MWD200F
Televison & Video Logo
248 people viewed this question
Top Televison & Video Experts
Electro Med Services...
