Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Have a Seeburg m100b juke box with two wire(black) that are unsoldered on the front side of the selectomatic. Need a picture of the front of this mechanism with cover removed so we can see where these wires go. We have a manual , but not helping.
3 Suggested Answers
  • 98 Answers
SOURCE: need parts....song list on front of juke box
The 24 songs shown are for decoration only....The original 1015 made in 1946-47 held only 24 records, so these "fake" title strips are placed there on the "One More Time" to retain the original look. If you have any other questions or need repair, my name is Rod and I can be reached at tech@wurlitzer-ohio.com.
Posted on Jul 08, 2010
  • 211 Answers
SOURCE: Hi, moving in 2 days,
Bit late for your question but there should be two shipping bolts that clamp the mechanism down . That's the whole playing frame plate , located about 2 oclock and 7 oclock. Tighten them to stop the mech bouncing during transport.
Posted on Jul 22, 2011
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
How do you lubricate a Seeburg Select-O-Matic juke box?
I like to use liquid bearings. the bottle comes with a long needle so it reaches easily to the areas, and you can get the lube exactly where you need it. Any thin machine oil is fine. Seeburg used to make sewing machines so sewing machine oil work great. Here is a mech chart.
OK This chart will be useless because it appears to be way too small.
If you email me with your model I can send you a PDF for the model you have.
50's & 60's Seeburg's may require credit & stepper unit lubrication also.
If it's pulling the same record in and out repeatedly or is just doing the sit and spin thing, you will have to use WD-40 to wash out all of the old grease and it may have to be partial disassembled in order to move and clean parts that are gummed up, by hand.
If you live with in 100 miles of Lancaster PA and would like a reasonably priced service call please call me (717)333-6933
Ed Gardner
edward_gardner@rocketmail.com
Jun 11, 2014 | Wurlitzer Jukebox 1015 One More Time...
My question is about the seeburg SPS-160 Juke Box
There is a "service switch" (bypass) that is mounted in the upper left corner (inside) of the title board (lid). It is designed to be moved in the run position when the lid is closed. If yours is still there it may be causing trouble since you moved it. This switch is often removed and covered in a ball of electrical tape and is laying in the bottom of the machine. The operators did this because the switch would frequently fail.
Troubleshooting Proceedure for this problem
1) Power off the jukebox.
2) Check the black RCA cable that plugs into the DCC (digital control center) this is labeled "Tormat" Just unplug it and plug it back in. There might be 2 more RCA connectors on the side of the mechanism control box (several black switches) Just unplug them and plug them back in. Make sure they ALL make really good connection and are tight. This cable carries the selection signal to the boxes.
3) Unplug the black and gray boxes. Examine these plugs for damage or corrosion and plug them back in again. Make sure that you check the little wire with the bullet plug located between the two plugs for the gray box.
4) After everything is back in place, power on the jukebox and see if it selects. If no result (continue)
5) On the side edge of the DCC there is a plastic cover that has test points under it. These voltages will need to be checked with a volt meter. With the power ON, touch the BLACK meter lead to the chassis (metal) and touch the RED lead to each of the screws ONE AT A TIME, be careful not to touch 2 or more of them together. Main concern is +27v, -27v, & 13v . Voltages can be + or - 2 volts.
If voltages are missing the power supply board in the DCC needs to be looked at.
If you are within 100 miles of Lancaster PA and would like a reasonably priced service call, Please call me (Ed Gardner) at (717) 333-6933 c0faecbb-5797-469a-8f9b-dea92f024201.jpg
Jan 26, 2013 | Audio Players & Recorders
My Parmak solar fence charge does not work. I have new battery. I opened the metal box with all the capacitors and wires and there is a yellow wire that came unsoldered leading from the little electrical...
We have what looks like the same charger. When you open the box right side up, from the front, the yellow wire is soldered to the right side of the circuit board right above the little white box that is marked .47363. It is next to a small round black transister.
Sep 22, 2010 | Parmak Solar Fence Charger
Seeburg selectomatic 200 [has been stored in garage for 30 years ] all funtions work properly except it will only play record for about 1 second, then eject & go to next selected record & play for...
1. Check to see that the end of record switch is OK or not shorted, same with the reject button on the back and all associated connections.
2. THESE THINGS NEED OIL! The trip lever (just to the right of the tonearm) may not be resetting fast enough, or at all, due to gummy grease. Buy the manual (eBay - any service man will insist that you have it.). It will show you where to lubricate everything. NO 3-in-1 or paraffin based oils.
Oct 24, 2009 | Audio Players & Recorders
Jukebox won't play selection, selects cd's 1-100 in order
Dear Amanda, Here is the manual,
Try re-programming your juke box per the instructions in the manual.
If you will e-mail me at deeddawg@bellsouth.net , I will E-mail you the 100 page manual in PDF format.
Gary.
Jun 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Juke box (seeburg 480 serieswill take coins but won't play record
YOU ARE SAYING THE MOTOR DOES NOT SPIN. TRY TO SPIN THE DRIVE SHAFT ON TOP OF MOTOR . DOES THE SHAFT TURN EASY. IF NO THEN YOU HAVE A MOTOR OR LUBRICATION.
PROBLEM.
DOES THE SCAN SWITCH, WHEN PUSHED TO SCAN DOES IT SCAN. IF IT SCANS BACK, AND FORTH 2 TIMES, YOU THEN HAVE A COIN CREDIT PROBLEM (MOST LIKELY )
ANSWER THE TWO QUESTION, OR STATEMENT. TO GET A MORE INTELLIGENT REPLY.
YOU HAVE OVER 2000 PARTS IN THAT MACHINE. YOU HAVE GIVEN A (WHY DONT IT WORK
QUESTION.)( there is no answer to the question. because of limited problem info)
DOCTOR FIX
IN-HOME JUKEBOX REPAIR
6362273300
May 09, 2009 | Audio Players & Recorders
Wailing sound when 1971 seeburg juke box is started
I amnot very familiar with Seeburgs but the trip switch activates at the end of the record playing and THAT mutes the amp. The amp should also be muted until the tone arm lands on the record. So I would suggest the problem is in the amp.
May 05, 2009 | Audio Players & Recorders
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
123 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
