In the fuse/relay box under the hood in front of the battery are 3 fan relays. 1 for low speed, and 2 for high speed. 1 of high speed is back up. check the relays first.
B3 CHECK FUSES
Key OFF.
Check the 10A RELAYS fuse located in the interior fuse junction panel and the 65A RAD FAN fuse located in the main fuse junction panel. (engine compartment)
744 is to do with your torque converter clutch circuit, intermittent malfunction. 325 is knock sensor malfunction. Has vehicle been shifting different, probably at highway speed? (cruising) Have you noticed engine "ping"/"rattle" on acceleration? These would be common occurences with these codes.
if you can get the codes... why don't you have a book that comes with the code reader
get yourself a Haynes manual #64200 at your local parts store or online
the easist way is to loosen the alternator slide the alternator down then slide the belt where it should go then pull up on the alternator again and bolt up Please rate my response thank you very much
