Question about Refrigerators
Starts and stops several times when it is try to operate
  • 163 Answers
Bad relay or overload to compressor
Posted on Mar 09, 2009
Hi My 2005 Same Dorado 85 Tractor. It starts from cold easily first time around. But once the engine has been running for several minutes it stops.
sounds like you could have a coolant temp sensor issue. If it senses the engine temperature higher than it actually is, it will tell the engine computer to shut down.
Also I'm not showing an 05 Eldorado, if you could give the correct information for your car, it would be very helpful
Feb 15, 2017 | Cars & Trucks
After several stops while running errands, will not run or runs rough. eventually stops running. wait for 1-2 hours, may start and run.
Could be heat related problem with ignition module. Can you check for spark the next time it quits ? Does it not turn over at all or spins but no run ?
Jul 27, 2015 | Cars & Trucks
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
Starts runs stops
Owen....sounds like fuel starvation check u have plenty fuel then clean ur fuel filter in line and in tank if u have 1, to check fuel is running ok remove fuel line the end thats connected to carb put in jar to catch fuel if runs ok thats good if slow flow or just dribbling blow through with air line then check again if ok reconnect
Mar 25, 2014 | Generac Measuring Tools & Sensors
Engine cranks, runs for 1 or 2 seconds and then stops.
Two items to check. The crankshaft sensor will reduce fuel pump pressure if it miscounts the RPM. The plastic strainer in the fuel tank can break apart and clog the pump intake in the tank. When the engine quits, the fuel pump is stopped and the loose particles are returned to the tank bottom.
In either case, try checking the fuel pressure at the test tap on the fuelrail.
Feb 03, 2014 | Ford Crown Victoria Cars & Trucks
Engine starts and runs for a second and then stops
Sounds like a key code issue. Was the key dropped and fell apart? the car will most likely need to go to an agent to repair.
Jan 28, 2014 | 2001 Volkswagen Cabrio
Stops during wash cycle for about 1 min then starts again, stops, then starts, stops then starts. Does this several times before finally finishing the cycle.
Are you getting an error code? If not, Try unplugging it for 20 minutes.
Then plug it back in, The ccu might have to be reset.
Jan 27, 2013 | Washing Machines
My 2004 gmc envoy starts but shut off after 1 or 2 seconds
Is there a Security light on the dash? Does it come on when the engine stops? If so, it could be having trouble reading the ignition key code. You would need to have that checked by a dealership.
Nov 13, 2011 | 2004 GMC Envoy
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
