Question about AmcorAire UCHW-H12AF2 Split System Air Conditioner
Inside blower fan barely running
I have a new system that was just installed but the inside blower fan will not run but at one speed, VERY slow. The unit freezes up very quickly with very little air running over the coils.
  • Ron Hubbard May 21, 2009
    It turned out that the set screw on the impeller shaft was loose. I was able to get in and tighten it and all is good.
  • Ken Bledsoe May 11, 2010
    Did a professional install unit? He or she should have checked unit out before the job was done. Call them back out they would like to know about the person doing the job did. The fan motor is a milti speed motor and can be wired up wrong
  • 478 Answers
Look at the control board for dip switches also the black lead(fast) should be on ac terminal. If the indoor coil is too small or there is restrictced air flow can also cause this problem,
Posted on Mar 12, 2009
Weak blower motor
Check good voltage and ground for blower motor. Actuators under the dash may be restricting air flow? High speed doesn't usually use a resister.
Check for hvac trouble codes, in my part of the country, some of the national brand autostores will check codes for free, if there are any.
If you think problem with blower motor, itself, replace it. Sometimes, you can remove blower motor, use jumper wires for voltage and ground, using inline fuse, come off the battery, see if it blows like you think it should?
May 07, 2016 | 1999 Chevrolet Lumina
3 speed fan barely changes speed
You are talking about your blower fan for the air conditioner and heater right? More information will be needed to solve the problem.
When you say it barely changes speeds, does that mean it doesnt speed up, or doesnt slow down? By that I mean, is it "stuck" on low, or high?
Most blower fans run at different speeds through the use of a multi-stage resistor built into the fan switch circuit. Low speed is a high value resistor, medium speed is a low value one, and high speed is the fan running without any resistance.
If your fan is running on high and doesnt seem to want to run on lower speeds, the resistor pack may be failing. If the fan is running on low speed only, it may be that the fan itself is beginning to fail, or that the lubricant in it has gotten gummy.
Dec 07, 2015 | Cars & Trucks
98 jetta tdi heater fan runs on high only.
needs a new reostat ,whever it is as some are seperate but some are built in to blower motor housing
Dec 21, 2010 | 1997 Volkswagen Jetta
Blower for heater only runs on high
bad inside switch. (happens often)
Sep 28, 2009 | 2000 Dodge Caravan
THE A/C BLOWER MOTOR ONLY RUNS ON HIGH SPEED, THE
Blower motor resistor,you need a new 1. It is close to the blower motor in the black casing.
Jul 27, 2009 | 2002 Chevrolet Silverado 1500HD
Blower fan runs at one speed - very low
There is a sensor on the indoor coil that needs to reach a certain temp before the fan speed will increase. Sounds like the unit is undercharged if the sensor isn't reaching the temp it needs to.
Mar 09, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
Inside Fan Relay location
replace blower motor switch on dash
Dec 18, 2008 | 1998 GMC Sierra
Heater fan is SLOW....
check to be sure that nothing has made a nest in your blower motor.. I have found mouse nests, rats nests, and even dead snakes inside the blower motor on these trucks..with all the extra weight inside the blower, the low speeds turn slow and will burn the resistor out quicker.
Oct 12, 2008 | 1994 Toyota Pickup
AmcorAire  UCHW-H12AF2 Split System Air Conditioner Logo
183 people viewed this question
Top Amcor Heating & Cooling Experts
Michael Youngman
Michael Youngman
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
