Question about Fargo DTC400 ID Card Printer Package
DTC400 Ver. 3.3.8 breaks printer ribbon
Printer breaks ribbon. What can cause this problem? How can I obtain troubleshooting info? Is there a repair shop in SF bay area?
  • 526 Answers
We are located in los angeles, if you would like to send the printer to us.
mostly likely the rollers are worn out, or possibly a bad o-ring.
our # is 310-671-8018
thanks adi
Posted on Apr 16, 2009
Troubleshooting
error code problem E020 ,0173
Aug 15, 2013 | Fargo DTC400 ID Card Printer Package
Panel Searching
Common problem with the DTC300, C30, DTC400. Upgrade the firmware and printer driver from Fargosupport.com. Then calibrate the ribbon sensor through the printer driver calibrate tab.
OnlineIdTech
Feb 06, 2010 | Fargo DTC-300 Thermal Card Printer
Fargo DTC400 is giving me "INVALID RIBBON" error
I think you or your machine have answered your own question. The machine said it isn't going to use the 300 ribbon and that is that.
I dont have experience with your particular model but I can tell you a Ford starter will not start a Chevrolet automobile.
I think you should take the 300 ribbon back and get a 400. If they wont take it back, trade somewhere else.
So, what do you say?
a
Sep 23, 2009 | Fargo DTC400 ID Card Printer Package
I have Broken ribbon message on the LCD display. I just changed the ribbon and the clean cartridge. Hellp
It could be that the printhead is damaged or the ribbon sensor needs repair. Call Zebra troubleshooting for help. If it is under warranty you can send the printer back to zebra for repair. Takes about 3-5 days. All the info is on their website. good luck.
Jun 16, 2009 | Zebra Eltron P330i Card Printer
Ribbon is breaking constantly in every print of card
in order of most likely
1 edge to edge settings in printer tool box are off.
2. print ribbon carriage (blue part you put the ribbon on is bad)
3. Bad ribbon
4. dealer needs to service to calibrate print head temp
tulsabiz.net for more info
Mar 27, 2009 | Datacard SP35 Printer
Printer keeps breaking the ribbon
first, try to calibrate the ribbon, if it does not work, you probably have worn out rollers, and possibly a broken o-ring. if you want more info, call us at 310-671-8018, thanks adi
Mar 25, 2009 | Fargo DTC400 ID Card Printer Package
Ribbon mis-cue?
When you have a ribbon mis-cue, first remove the ribbon. Go to the printer driver, printing preferences, calibrate, sensors. Click sesors then send... You should hear 2 beeps. Put you ribbon back in and try to print again.
If you still have the mis-cue it is a belt issue all DTC400's made 2006 and prior have had this belt issue. I don't recommend fixing this yourself, send it to a authorized Fargo repair center. This way it is under warranty.
Jan 05, 2009 | Fargo DTC400 ID Card Printer Package
My DTC 400 bladge printer jams a lot.
The DTC400 has an o ring that drives the card feed rollers. Fargo has had a problem on older DTC400 printers with the o ring stretched or broke. This causes irregular feed roller issues, ribbon breakage or misalignment of print registration.
It is recommended to do a ribbon sensor calibration. This can be done through your print driver using the directions in this link.
Your DTC400 came with a two year manufacturer warranty. Contact Fargo Technical Support at 800-459-5636.
For more information about id card printer systems, visit our website at www.safecardid.com
Nov 13, 2008 | Fargo Office Equipment & Supplies
New ctg. change problems
In the printing preferences there is an auto detect ribbon button . you should select it.
Your ribbon will be updated. Also if printer asks you if the ribbon is correct select yes. The printer will then print on whatever ribbon you have intalled. This doesnt work with test prints
Dec 26, 2007 | Fargo Persona C30 Thermal Card Printer
Fargo DTC400 ID Card Printer Package Logo
270 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
