Question about Intervideo WinDVD 5 for PC
Extended OEM Dll dll is missing hence unable to start windvr
Ascddmi.dll missing
Hi Les,
Since am not using ASUS PC , I've searching and found the following article regarding ASCDDMI.DLL error.
Ascddmi dll error fix solutions and file information
Hope it helps.
Apr 10, 2014 | Microsoft Windows 7 Home Premium 64BIT...
How to install msvcp90.dll
u can go to this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case :)
Dec 17, 2010 | Microsoft Windows XP Professional SP3 Full...
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
I am unable to install NokiaN72 software. The problem is library msvcr80 dll is not identified . Hence it is to be installed first. How ?
You can install msvcr80.dll file from here:
Oct 18, 2010 | Computers & Internet
Missing msvcr80.dll
Aug 16, 2010 | Microsoft Windows XP Professional SP3 Full...
Unable to get onto internet explorer
Thank you for using FixYa.
Use another computer to download "combofix" from bleeping computer, run this and part of the fix is to reset the IE settings back
IE should restart after this, If not download say Firefox and get this installed and see if that will work, most cases it will and IE not, it can be bugs causeing your IE to stop working
Nov 17, 2009 | Acer Aspire 4530-5889 Notebook PC
My webcam is not working...
avifil32.dll or avifil32 processes info for Microsoft AVI File support library.
If Windows is unable to run applications due to a .dll error, this .dll may be missing or you may have registry error. Such errors can heavily influence the performance of your PC
Sep 14, 2009 | Acer Aspire 5630 Notebook
When i startup my laptop i get massage that i lost m3plugin
Windows errors related to m3plugin.dll?
If Windows is unable to run applications due to a .dll error, this .dll may be missing or you may have registry error. Such errors can heavily influence the performance of your PC. I strongly recommend that you run this free registry scan.
Here you can download m3plugin.dll free of charge. The file is compressed so you need an unzip software in order to use the file. We recommend you to read the tutorial how to unzip and install the files. Use the link below to start downloading m3plugin.dll.
arrow_w.gif Recommended: Fix m3plugin.dll Errors arrow_w.gif Enhance your PC-speed: Free Performance Scan arrow_w.gif File description: MyWebSearch Idle Monitor, v. arrow_w.gif Filesize to download: 2.4 kb
download_icon.gif Click here to go to the download of m3plugin.dll
Jun 09, 2009 | Intel Motherboard
Just visit this site...
this will help in case of missing or downloading dll's .
helped in my problem. :)
Dec 20, 2008 | Computers & Internet
Intervideo WinDVD 5 for PC Logo
211 people viewed this question
Top Intervideo Computers & Internet Experts
David Payne
David Payne
Are you an Intervideo Computer and Internet Expert? Answer questions, earn points and help others
